uart = UART(3, 19200)
sensor.skip_frames(time = 2000) # Wait for settings take effect.
red_threshold_01 = (91, 100, 127, -9, -20, 20)
blobs = img.find_blobs([red_threshold_01], area_threshold=150)
# print(blobs)
for b in blobs:
img.draw_rectangle(b[0:4])
img.draw_cross(b[5], b[6])
m=[b[5],b[6]]
print(m)
uart.write(m)
print(clock.fps()) # Note: OpenMV Cam runs about half as fast when connected
![0_1525939737111_6752PPZP32PTPXV_L@6B%C4.png](https://fcdn.singtown.com/35e91385-72e5-441d-964e-a869d1850504.png)
