  • 两个MV之间通信怎么清空接收方UART.ANY()里的数据从而重新查询。
      from pyb import Servo
      import cpufreq
      import pyb
      thresholds = [(58, 88, 57, -4, 20, 70)] # generic_red_thresholds
                                                  # generic_green_thresholds
                                                  # generic_blue_thresholds
      threshold2 = [(30, 47, -39, 19, 20, 42)]
      avg=[0,0,0,0,0,0,0,0,0,0,0,0]
      sort2_servo=Servo(1)
      led = pyb.LED(3)
      #cpufreq.set_frequency(cpufreq.CPUFREQ_216MHZ)
      uart=UART(3,115200)
      ROI=(0,0,1,1)
          data = 0
          sort2_servo.angle(-900)
          time.sleep(20)
          #time.sleep(10)
          blobs = img.find_blobs([thresholds[0]], pixels_threshold=80, area_threshold=850, merge=True)
                    ROI = max_blob.rect()
                    xc = max_blob.cx()
                    yc = max_blob.cy()
                    x = max_blob.x()
                    y = max_blob.y()
                    xn = int(xc-(xc-x)*7/10)
                    yn = int(yc-(yc-y)*7/10)
                    wn = (xc-xn)*2
                    hn = (yc-yn)*2
                    ROI = (xn, yn, wn, hn)
                    img.binary(thresholds)
                    #Bimg.erode(2)
                    #img.dilate(1)
                    avg = statistics.mean()
                    print(avg)
                    if(uart.any()):
                         data = uart.readline()
                    if ( data!=0):#avg>=50 and avg<=95 or
                        print("bad")
                        print(data)
                        print(uart.any())
                        #led.on()
                        #time.sleep(150)
                        #ed.off()
                        sort2_servo.angle(0)       #添加时期2018.4.20
                        time.sleep(1000)        #添加时期2018.4.20
                        sort2_servo.angle(-900)           #添加时期2018.4.20
                        data = 0
                    elif (avg>95):
                        time.sleep(100)
                        print("good")
                        print(uart.any())
          #print(clock.fps())
          #print(cpufreq.get_frequency())
    • 直接uart.read(timeout_char=0)应该可以立即把数据读出来,就清空了缓冲区。
    • @kidswong999两个MV之间通信怎么清空接收方UART.ANY()里的数据从而重新查询。 中说:
      但是报错了大佬。
