两个MV之间通信怎么清空接收方UART.ANY()里的数据从而重新查询。
import sensor, image, time from pyb import UART from pyb import Servo import cpufreq import pyb threshold_index = 0 # 0 for red, 1 for green, 2 for blue # Color Tracking Thresholds (L Min, L Max, A Min, A Max, B Min, B Max) # The below thresholds track in general red/green/blue things. You may wish to tune them... thresholds = [(58, 88, 57, -4, 20, 70)] # generic_red_thresholds # generic_green_thresholds # generic_blue_thresholds threshold2 = [(30, 47, -39, 19, 20, 42)] avg=[0,0,0,0,0,0,0,0,0,0,0,0] sort2_servo=Servo(1) led = pyb.LED(3) #cpufreq.set_frequency(cpufreq.CPUFREQ_216MHZ) sensor.reset() sensor.set_pixformat(sensor.RGB565) sensor.set_framesize(sensor.QQVGA) sensor.skip_frames(time = 2000) sensor.set_auto_gain(False) # must be turned off for color tracking sensor.set_auto_whitebal(False) # must be turned off for color tracking clock = time.clock() # Only blobs that with more pixels than "pixel_threshold" and more area than "area_threshold" are # returned by "find_blobs" below. Change "pixels_threshold" and "area_threshold" if you change the # camera resolution. "merge=True" merges all overlapping blobs in the image. uart=UART(3,115200) def find_max(blobs): max_size=0 for blob in blobs: if blob[2]*blob[3] > max_size: max_blob=blob max_size = blob[2]*blob[3] return max_blob ROI=(0,0,1,1) while(True): data = 0 clock.tick() img = sensor.snapshot() sort2_servo.angle(-900) time.sleep(20) #time.sleep(10) blobs = img.find_blobs([thresholds[0]], pixels_threshold=80, area_threshold=850, merge=True) if blobs: max_blob = find_max(blobs) ROI = max_blob.rect() xc = max_blob.cx() yc = max_blob.cy() x = max_blob.x() y = max_blob.y() xn = int(xc-(xc-x)*7/10) yn = int(yc-(yc-y)*7/10) wn = (xc-xn)*2 hn = (yc-yn)*2 ROI = (xn, yn, wn, hn) img.binary(thresholds) #Bimg.erode(2) #img.dilate(1) statistics=img.get_statistics(roi=ROI) avg = statistics.mean() print(avg) if(uart.any()): data = uart.readline() if ( data!=0):#avg>=50 and avg<=95 or print("bad") print(data) print(uart.any()) #led.on() #time.sleep(150) #ed.off() sort2_servo.angle(0) #添加时期2018.4.20 time.sleep(1000) #添加时期2018.4.20 sort2_servo.angle(-900) #添加时期2018.4.20 time.sleep(1000) #添加时期2018.4.20 data = 0 elif (avg>95): sort2_servo.angle(-900) #添加时期2018.4.20 time.sleep(100) print("good") print(uart.any()) #print(clock.fps()) #print(cpufreq.get_frequency())
直接uart.read(timeout_char=0)应该可以立即把数据读出来,就清空了缓冲区。
