这是我写的代码,我是接受到串口猜开启人脸识别的 可一运行程序 芯片就发烫
import sensor, time, image, pyb, machine from pyb import UART sensor.reset() sensor.set_contrast(3) sensor.set_gainceiling(16) sensor.set_framesize(sensor.HQVGA) sensor.set_pixformat(sensor.GRAYSCALE) uart = UART(3, 19200, timeout_char = 1000) face_cascade = image.HaarCascade("frontalface", stages=25) print(face_cascade) # FPS clock clock = time.clock() while (True): clock.tick() if uart.any(): a = uart.readline() print (a) start = pyb.millis() while a==b'1': img = sensor.snapshot() objects = img.find_features(face_cascade, threshold=0.75, scale_factor=1.25) for r in objects: img.draw_rectangle(r) if r[1]>50: print ('incorrect') elif r[1]<50: print ('correct') if pyb.millis() - start>60000: print ('failed') break if objects: print ('success') break
发烫问题不大,没什么事。
