大佬们帮忙康康我的这个,感觉逻辑上行得通,就是舵机没办法正常转(转的幅度不大,而且感觉并不是和检测到的偏离很一致)
THRESHOLD = (0, 30, -10, 10, -20, 10) import sensor, image, time from pyb import Servo import car s1 = Servo(1) # servo on position 1 (P7) sensor.reset() sensor.set_pixformat(sensor.RGB565) sensor.set_framesize(sensor.QQQVGA) sensor.skip_frames(time = 2000) clock = time.clock() while(True): clock.tick() img = sensor.snapshot().binary([THRESHOLD]) line = img.get_regression([(100,100,0,0,0,0)], robust = True) if (line): print('角度:',line.theta()) if(line.theta()<10 or 170<line.theta()): s1.angle(0) print("中间") elif(90<line.theta()<170): s1.angle(180 - line.theta()) print("偏左") else : s1.angle(line.theta()) print("偏右") else: car.run(50,-50) pass
你把180 - line.theta()的值打印出来看看。
This post is deleted!
所以有什么问题。。。
你要发送实际的结构图,和目的。
