颜色和模板同时匹配,无法识别颜色?
import time, sensor, image from pyb import LED from pyb import UART from image import SEARCH_EX, SEARCH_DS thresholds1 = [(30, 100, 15, 127, 15, 127)]# generic_yeliow_thresholds识别到黄线 # Reset sensor sensor.reset() # Set sensor settings sensor.set_contrast(1) sensor.set_gainceiling(16) # Max resolution for template matching with SEARCH_EX is QQVGA sensor.set_framesize(sensor.QQVGA) sensor.skip_frames(time = 2000) sensor.set_auto_gain(False) # must be turned off for color tracking sensor.set_auto_whitebal(False) # must be turned off for color tracking # You can set windowing to reduce the search image. #sensor.set_windowing(((640-80)//2, (480-60)//2, 80, 60)) sensor.set_pixformat(sensor.GRAYSCALE) # Load template. # Template should be a small (eg. 32x32 pixels) grayscale image. template8 = image.Image("/pgm_8.pgm") template9 = image.Image("/pgm_9.pgm") template10 = image.Image("/pgm_10.pgm") template11 = image.Image("/pgm_11.pgm") template12 = image.Image("/pgm_12.pgm") template13 = image.Image("/pgm_13.pgm") red_led = LED(1) green_led = LED(2) blue_led = LED(3) ir_led = LED(4) clock = time.clock() # Run template matching while (True): clock.tick() img = sensor.snapshot() # find_template(template, threshold, [roi, step, search]) # ROI: The region of interest tuple (x, y, w, h). # Step: The loop step used (y+=step, x+=step) use a bigger step to make it faster. # Search is either image.SEARCH_EX for exhaustive search or image.SEARCH_DS for diamond search # # Note1: ROI has to be smaller than the image and bigger than the template. # Note2: In diamond search, step and ROI are both ignored. r8 = img.find_template(template8, 0.70, step=4, search=SEARCH_EX) #, roi=(10, 0, 60, 60)) if r8: blue_led.on() time.sleep(500) blue_led.off() #img.draw_rectangle(r8) r9 = img.find_template(template9, 0.70, step=4, search=SEARCH_EX) #, roi=(10, 0, 60, 60)) if r9: green_led.on() time.sleep(500) green_led.off() #img.draw_rectangle(r9) r10 = img.find_template(template10, 0.70, step=4, search=SEARCH_EX) #, roi=(10, 0, 60, 60)) if r10: ir_led.on() time.sleep(500) ir_led.off() #img.draw_rectangle(r10) r13 = img.find_template(template13, 0.70, step=4, search=SEARCH_EX) #, roi=(10, 0, 60, 60)) if r13: green_led.on() time.sleep(500) green_led.off() img=img.to_rgb565() blob = img.find_blobs([thresholds1[0]], pixels_threshold=200, area_threshold=200, merge=True) if blob: red_led.on() time.sleep(500) red_led.off() # img.draw_rectangle(r13) print(clock.fps())
目前问题是识别到颜色的时候,不是对应的灯亮
你上传一下具体的模版。好让我可以重复实现你的现象。
说清楚:
1,想要得到什么现象,当看到什么的时候,什么灯亮。
2,现在哪里不一致。
