  • 颜色和模板同时匹配,无法识别颜色?
    • import time, sensor, image
      from pyb import LED
      thresholds1 = [(30, 100, 15, 127, 15, 127)]# generic_yeliow_thresholds识别到黄线
      # Reset sensor
      # Set sensor settings
      # Load template.
      template8 = image.Image("/pgm_8.pgm")
      template9 = image.Image("/pgm_9.pgm")
      template10 = image.Image("/pgm_10.pgm")
      template11 = image.Image("/pgm_11.pgm")
      template12 = image.Image("/pgm_12.pgm")
      template13 = image.Image("/pgm_13.pgm")
      red_led   = LED(1)
      green_led = LED(2)
      blue_led  = LED(3)
      ir_led    = LED(4)
      # Run template matching
          r8 = img.find_template(template8, 0.70, step=4, search=SEARCH_EX) #, roi=(10, 0, 60, 60))
          if r8:
              blue_led.on()
              time.sleep(500)
              blue_led.off()
              #img.draw_rectangle(r8)
          r9 = img.find_template(template9, 0.70, step=4, search=SEARCH_EX) #, roi=(10, 0, 60, 60))
          if r9:
              green_led.on()
              time.sleep(500)
              green_led.off()
              #img.draw_rectangle(r9)
          r10 = img.find_template(template10, 0.70, step=4, search=SEARCH_EX) #, roi=(10, 0, 60, 60))
          if  r10:
               ir_led.on()
               time.sleep(500)
               ir_led.off()
              #img.draw_rectangle(r10)
          r13  = img.find_template(template13, 0.70, step=4, search=SEARCH_EX) #, roi=(10, 0, 60, 60))
          if   r13:
              green_led.on()
              time.sleep(500)
              green_led.off()
          img=img.to_rgb565()
          blob = img.find_blobs([thresholds1[0]], pixels_threshold=200, area_threshold=200, merge=True)
          if blob:
              red_led.on()
              time.sleep(500)
              red_led.off()
              # img.draw_rectangle(r13)
    • 目前问题是识别到颜色的时候,不是对应的灯亮
    • 你上传一下具体的模版。好让我可以重复实现你的现象。
      说清楚:
      1,想要得到什么现象,当看到什么的时候,什么灯亮。
      2,现在哪里不一致。
