运行程序时报错咋处理
从SD卡里导入文件进行特征点检测,提示运行内存不足,除了降低图片分辨率外,还有其他技巧可以解决这个问题吗?
import sensor, time, image from pid import PID from pyb import Servo pan_servo=Servo(1) tilt_servo=Servo(2) pan_pid = PID(p=0.10, i=0, imax=90) tilt_pid = PID(p=0.10, i=0, imax=90) sensor.reset() sensor.set_contrast(3) sensor.set_gainceiling(16) sensor.set_framesize(sensor.VGA) sensor.set_windowing((320, 240)) sensor.set_pixformat(sensor.GRAYSCALE) sensor.skip_frames(time = 2000) sensor.set_auto_gain(False, value=100) def draw_keypoints(img, kpts): if kpts: print(kpts) img.draw_keypoints(kpts) img = sensor.snapshot() time.sleep(1000) kpts1 = image.load_descriptor("/A1.orb") kpts2 = image.load_descriptor("/A2.orb") kpts3 = image.load_descriptor("/A3.orb") kpts4 = image.load_descriptor("/A4.orb") kpts5 = image.load_descriptor("/A5.orb") kpts6 = image.load_descriptor("/A6.orb") kpts7 = image.load_descriptor("/A7.orb") kpts8 = image.load_descriptor("/A8.orb") kpts9 = image.load_descriptor("/B1.orb") kpts10 = image.load_descriptor("/B2.orb") kpts11 = image.load_descriptor("/B3.orb") kpts12 = image.load_descriptor("/B4.orb") kpts13 = image.load_descriptor("/B5.orb") kpts14 = image.load_descriptor("/B6.orb") kpts15 = image.load_descriptor("/B7.orb") kpts16 = image.load_descriptor("/B8.orb") kpts17 = image.load_descriptor("/C1.orb") kpts18 = image.load_descriptor("/C2.orb") kpts19 = image.load_descriptor("/C3.orb") kpts20 = image.load_descriptor("/C4.orb") kpts21 = image.load_descriptor("/C5.orb") kpts22 = image.load_descriptor("/C6.orb") kpts23 = image.load_descriptor("/C7.orb") kpts24 = image.load_descriptor("/C8.orb") kpts25 = image.load_descriptor("/D1.orb") kpts26 = image.load_descriptor("/D2.orb") kpts27 = image.load_descriptor("/D3.orb") kpts28 = image.load_descriptor("/D4.orb") kpts29 = image.load_descriptor("/D5.orb") kpts30 = image.load_descriptor("/D6.orb") kpts31 = image.load_descriptor("/D7.orb") kpts32 = image.load_descriptor("/D8.orb") img = sensor.snapshot() clock = time.clock() while (True): clock.tick() img = sensor.snapshot() pan_servo.angle(0) time.sleep(200) tilt_servo.angle(-17) time.sleep(200) kptsA = img.find_keypoints(max_keypoints=150, threshold=10, normalized=True) if (kptsA): match1 = image.match_descriptor(kpts1, kptsA, threshold=85) match2 = image.match_descriptor(kpts2, kptsA, threshold=85) match3 = image.match_descriptor(kpts3, kptsA, threshold=85) match4 = image.match_descriptor(kpts4, kptsA, threshold=85) match5 = image.match_descriptor(kpts5, kptsA, threshold=85) match6 = image.match_descriptor(kpts6, kptsA, threshold=85) match7 = image.match_descriptor(kpts7, kptsA, threshold=85) match8 = image.match_descriptor(kpts8, kptsA, threshold=85) match9 = image.match_descriptor(kpts9, kptsA, threshold=85) match10 = image.match_descriptor(kpts10, kptsA, threshold=85) match11 = image.match_descriptor(kpts11, kptsA, threshold=85) match12 = image.match_descriptor(kpts12, kptsA, threshold=85) match13 = image.match_descriptor(kpts13, kptsA, threshold=85) match14 = image.match_descriptor(kpts14, kptsA, threshold=85) match15 = image.match_descriptor(kpts15, kptsA, threshold=85) match16 = image.match_descriptor(kpts16, kptsA, threshold=85) match17 = image.match_descriptor(kpts17, kptsA, threshold=85) match18 = image.match_descriptor(kpts18, kptsA, threshold=85) match19 = image.match_descriptor(kpts19, kptsA, threshold=85) match20 = image.match_descriptor(kpts20, kptsA, threshold=85) match21 = image.match_descriptor(kpts21, kptsA, threshold=85) match22 = image.match_descriptor(kpts22, kptsA, threshold=85) match23 = image.match_descriptor(kpts23, kptsA, threshold=85) match24 = image.match_descriptor(kpts24, kptsA, threshold=85) match25 = image.match_descriptor(kpts25, kptsA, threshold=85) match26 = image.match_descriptor(kpts26, kptsA, threshold=85) match27 = image.match_descriptor(kpts27, kptsA, threshold=85) match28 = image.match_descriptor(kpts28, kptsA, threshold=85) match29 = image.match_descriptor(kpts29, kptsA, threshold=85) match30 = image.match_descriptor(kpts30, kptsA, threshold=85) match31 = image.match_descriptor(kpts31, kptsA, threshold=85) match32 = image.match_descriptor(kpts32, kptsA, threshold=85) if (match1.count()>10): pan_servo.angle(40) time.sleep(400) pan_servo.angle(0) time.sleep(400) elif (match2.count()>10): pan_servo.angle(40) time.sleep(400) pan_servo.angle(0) time.sleep(400) elif (match3.count()>10): pan_servo.angle(40) time.sleep(400) pan_servo.angle(0) time.sleep(400) elif (match4.count()>10): pan_servo.angle(40) time.sleep(400) pan_servo.angle(0) time.sleep(400) elif (match5.count()>10): pan_servo.angle(40) time.sleep(400) pan_servo.angle(0) time.sleep(400) elif (match6.count()>10): pan_servo.angle(40) time.sleep(400) pan_servo.angle(0) time.sleep(400) elif (match7.count()>10): pan_servo.angle(40) time.sleep(400) pan_servo.angle(0) time.sleep(400) elif (match8.count()>10): pan_servo.angle(40) time.sleep(400) pan_servo.angle(0) time.sleep(400) elif (match9.count()>10): tilt_servo.angle(-47) time.sleep(400) tilt_servo.angle(-17) time.sleep(400) elif (match10.count()>10): tilt_servo.angle(-47) time.sleep(400) tilt_servo.angle(-17) time.sleep(400) elif (match11.count()>10): tilt_servo.angle(-47) time.sleep(400) tilt_servo.angle(-17) time.sleep(400) elif (match12.count()>10): tilt_servo.angle(-47) time.sleep(400) tilt_servo.angle(-17) time.sleep(400) elif (match13.count()>10): tilt_servo.angle(-47) time.sleep(400) tilt_servo.angle(-17) time.sleep(400) elif (match14.count()>10): tilt_servo.angle(-47) time.sleep(400) tilt_servo.angle(-17) time.sleep(400) elif (match15.count()>10): tilt_servo.angle(-47) time.sleep(400) tilt_servo.angle(-17) time.sleep(400) elif (match16.count()>10): tilt_servo.angle(-47) time.sleep(400) tilt_servo.angle(-17) time.sleep(400) elif (match17.count()>10): pan_servo.angle(-35) time.sleep(400) pan_servo.angle(0) time.sleep(400) elif (match18.count()>10): pan_servo.angle(-35) time.sleep(400) pan_servo.angle(0) time.sleep(400) elif (match19.count()>10): pan_servo.angle(-35) time.sleep(400) pan_servo.angle(0) time.sleep(400) elif (match20.count()>10): pan_servo.angle(-35) time.sleep(400) pan_servo.angle(0) time.sleep(400) elif (match21.count()>10): pan_servo.angle(-35) time.sleep(400) pan_servo.angle(0) time.sleep(400) elif (match22.count()>10): pan_servo.angle(-35) time.sleep(400) pan_servo.angle(0) time.sleep(400) elif (match23.count()>10): pan_servo.angle(-35) time.sleep(400) pan_servo.angle(0) time.sleep(400) elif (match24.count()>10): pan_servo.angle(-35) time.sleep(400) pan_servo.angle(0) time.sleep(400) elif (match25.count()>10): tilt_servo.angle(13) time.sleep(400) tilt_servo.angle(-17) time.sleep(400) elif (match26.count()>10): tilt_servo.angle(13) time.sleep(400) tilt_servo.angle(-17) time.sleep(400) elif (match27.count()>10): tilt_servo.angle(13) time.sleep(400) tilt_servo.angle(-17) time.sleep(400) elif (match28.count()>10): tilt_servo.angle(13) time.sleep(400) tilt_servo.angle(-17) time.sleep(400) elif (match29.count()>10): tilt_servo.angle(13) time.sleep(400) tilt_servo.angle(-17) time.sleep(400) elif (match30.count()>10): tilt_servo.angle(13) time.sleep(400) tilt_servo.angle(-17) time.sleep(400) elif (match31.count()>10): tilt_servo.angle(13) time.sleep(400) tilt_servo.angle(-17) time.sleep(400) elif (match32.count()>10): tilt_servo.angle(13) time.sleep(400) tilt_servo.angle(-17) time.sleep(400) else : pan_servo.angle(0) time.sleep(200) tilt_servo.angle(-17) time.sleep(200) print(kptsA, "matched:%d dt:%d"%(match4.count(), match4.theta())) img.draw_string(0, 0, "FPS:%.2f"%(clock.fps()))
不要在一开始全部把特征点读取进来。内存不够。
在循环里添加for循环。参考这个代码:https://book.openmv.cc/image/mulity-template-match.html
