  • 官网上的!!!巡线小车例程报错
    • THRESHOLD = (5, 70, -23, 15, -57, 0) # Grayscale threshold for dark things...
      from pyb import LED
      import car
      rho_pid = PID(p=0.4, i=0)
      theta_pid = PID(p=0.001, i=0)
      LED(1).on()
      LED(2).on()
      LED(3).on()
      sensor.set_vflip(True)
      sensor.set_hmirror(True)
          if (line):
              if line.theta()>90:
                  theta_err = line.theta()-180
              if line.magnitude()>8:
                  car.run(50+output, 50-output)
                  car.run(0,0)
              car.run(50,-50)
              pass
          #print(clock.fps())
      from pyb import Pin, Timer
      ain1 = Pin('P0', Pin.OUT_PP)
      ain2 = Pin('P1', Pin.OUT_PP)
      bin1 = Pin('P2', Pin.OUT_PP)
      bin2 = Pin('P3', Pin.OUT_PP)
      ain1.low()
      ain2.low()
      bin1.low()
      bin2.low()
      pwma = Pin('P7')
      pwmb = Pin('P8')
      tim = Timer(4, freq=1000)
      ch1.pulse_width_percent(0)
      ch2.pulse_width_percent(0)
      if inverse_left==True:
      left_speed=(-left_speed)
      if inverse_right==True:
      right_speed=(-right_speed)
      if left_speed < 0:
          ain1.low()
          ain2.high()
          ain1.high()
          ain2.low()
      if right_speed < 0:
          bin1.low()
          bin2.high()
          bin1.high()
          bin2.low()
      from pyb import millis
      from math import pi, isnan
      class PID:
          _RC = 1/(2 * pi * 20)
              self._kp = float(p)
              self._ki = float(i)
              self._kd = float(d)
              self._imax = abs(imax)
              tnow = millis()
              dt = tnow - self._last_t
              output = 0
                  dt = 0
                  self.reset_I()
              self._last_t = tnow
              output += error * self._kp
                      derivative = 0
                      self._last_derivative = 0
                  self._last_error = error
              output *= scaler
                  output += self._integrator
              return output
          def reset_I(self):
              self._integrator = 0
    • 它的错误是这样的
