  • 程序运行为什么会卡顿?
    • from pyb import Pin
      flag=0
          for c in img.find_circles(threshold = 3500, x_margin = 10, y_margin = 10, r_margin = 10,
              area = (c.x()-c.r(), c.y()-c.r(), 2*c.r(), 2*c.r())#area为识别到的圆的区域,即圆的外接矩形框
              print(statistics)
              #(0,100,0,120,0,120)是红色的阈值,所以当区域内的众数(也就是最多的颜色),范围在这个阈值内,就说明是红色的圆。
              if 0<statistics.l_mode()<100 and 0<statistics.a_mode()<127 and 0<statistics.b_mode()<127:  #if the circle is red
                 img.draw_circle(c.x(), c.y(), c.r(), color = (255, 0, 0))#识别到的红色圆形用红色的圆框出来
                 flag=1
              if 0<statistics.l_mode()<100 and -40<statistics.a_mode()<30 and 0<statistics.b_mode()<50:#if the circle is green
                  img.draw_circle(c.x(), c.y(), c.r(), color = (0, 255, 0))#识别到的绿色圆形用绿色的圆框出来
                  time.sleep(1) # 延时 1 毫秒
                     img.draw_circle(c.x(), c.y(), c.r(), color = (255, 0, 0))#识别到的红色圆  形用红色的圆框出来
                     flag=2
                      flag=3
              if  0<statistics.l_mode()<100 and -40<statistics.a_mode()<0 and -40<statistics.b_mode()<20:#if the circle is blue
                   img.draw_circle(c.x(), c.y(), c.r(), color = (0, 0, 255))#识别到的蓝色圆形用蓝色的圆框出来
                      flag=2
                      flag=3
              while(flag):
                      if  flag==1:
                          p_out = Pin('P0', Pin.OUT_PP)#设置p_out为输入引脚
                          p_out.high()#设置p0引脚为高
                      elif  flag==2:
                          p_out = Pin('P1', Pin.OUT_PP)#设置p_out为输入引脚
                      elif flag==3:
                          p_out = Pin('P2', Pin.OUT_PP)#设置p_out为输入引脚
                          print("default")
      print("FPS %f" % clock.fps())
    • 你里面有一个死循环,45行。
