  • 我电脑运行程序可以,但是脱机运行后就会卡住怎么回事?
    • # Hello World Example
      import ujson
      import lcd
      uart = UART(3, 19200)
      # Set sensor settings
      lcd.init()
      led=pyb.LED(3)
      templates1= ["/16.pgm","/161.pgm","/162.pgm"]  #正方形
      templates2= ["/12.pgm","/121.pgm","/122.pgm"]  #五角星
      templates3= ["/13.pgm","/131.pgm","/132.pgm"]  #n
      templates4= ["/14.pgm","/141.pgm","/142.pgm"]  #三角形
      templates5= ["/11.pgm","/111.pgm","/112.pgm"]  #圆
      templates6= ["/15.pgm","/151.pgm","/152.pgm"]  #六边形
          led.on()
          lcd.display(sensor.snapshot())
          #x=str(10)
          #uart.write(x+'\r\n')
          #print(x)
          #time.sleep(1000)
          if(uart.any()):
              d=uart.readchar()-48
              #print(d)
              if d==1:
                  print(d)
                  for t in templates1:
                      template = image.Image(t)
                      if r:
                          img.draw_rectangle(r, color=0)
                          str1="16"
                          uart.write(str1+'\r\n')
                          print(str1)
                          time.sleep(2)
                          break
                          #print(2)
                          for t in templates2:
                              if r:
                                  str1="12"
                                  print(str1)
                                  time.sleep(2)
                                  break
                                  #print(3)
                                  for t in templates3:
                                      if r:
                                          str1="13"
                                          print(str1)
                                          time.sleep(2)
                                          break
                                          #print(4)
                                          for t in templates4:
                                              if r:
                                                  str1="14"
                                                  print(str1)
                                                  time.sleep(2)
                                                  break
                                                  #print(5)
                                                  for t in templates5:
                                                      if r:
                                                          str1="11"
                                                          print(str1)
                                                          time.sleep(2)
                                                          break
                                                          for t in templates6:
                                                              if r:
        str1="15"
        print(str1)
        time.sleep(2)
        break
        str1="99"
        time.sleep(2)
        break
                                                          break
                                                  break
                                          break
                                  break
                          break
    • 什么叫做卡住?具体的现象是什么。
    • @kidswong999 运行一会后,画面卡住,不再运行程序,数据不再传输
    • This post is deleted!
