我电脑运行程序可以,但是脱机运行后就会卡住怎么回事?
# Hello World Example # # Welcome to the OpenMV IDE! Click on the green run arrow button below to run the script! import sensor, image, time,pyb from image import SEARCH_EX, SEARCH_DS from pyb import UART import ujson import lcd uart = UART(3, 19200) sensor.reset() # Set sensor settings sensor.set_contrast(1) sensor.set_gainceiling(16) # Max resolution for template matching with SEARCH_EX is QQVGA sensor.set_framesize(sensor.QQVGA) # You can set windowing to reduce the search image. #sensor.set_windowing(((640-80)//2, (480-60)//2, 80, 60)) sensor.set_pixformat(sensor.GRAYSCALE) lcd.init() led=pyb.LED(3) templates1= ["/16.pgm","/161.pgm","/162.pgm"] #正方形 templates2= ["/12.pgm","/121.pgm","/122.pgm"] #五角星 templates3= ["/13.pgm","/131.pgm","/132.pgm"] #n templates4= ["/14.pgm","/141.pgm","/142.pgm"] #三角形 templates5= ["/11.pgm","/111.pgm","/112.pgm"] #圆 templates6= ["/15.pgm","/151.pgm","/152.pgm"] #六边形 while(True): led.on() img = sensor.snapshot() # Take a picture and return the image. lcd.display(sensor.snapshot()) #x=str(10) #uart.write(x+'\r\n') #print(x) #time.sleep(1000) if(uart.any()): d=uart.readchar()-48 #print(d) if d==1: print(d) for t in templates1: template = image.Image(t) r = img.find_template(template, 0.70, step=4, search=SEARCH_EX) #, roi=(10, 0, 60, 60)) if r: img.draw_rectangle(r, color=0) str1="16" uart.write(str1+'\r\n') print(str1) time.sleep(2) break else: #print(2) for t in templates2: template = image.Image(t) r = img.find_template(template, 0.70, step=4, search=SEARCH_EX) #, roi=(10, 0, 60, 60)) if r: img.draw_rectangle(r, color=0) str1="12" uart.write(str1+'\r\n') print(str1) time.sleep(2) break else: #print(3) for t in templates3: template = image.Image(t) r = img.find_template(template, 0.70, step=4, search=SEARCH_EX) #, roi=(10, 0, 60, 60)) if r: img.draw_rectangle(r, color=0) str1="13" uart.write(str1+'\r\n') print(str1) time.sleep(2) break else: #print(4) for t in templates4: template = image.Image(t) r = img.find_template(template, 0.70, step=4, search=SEARCH_EX) #, roi=(10, 0, 60, 60)) if r: img.draw_rectangle(r, color=0) str1="14" uart.write(str1+'\r\n') print(str1) time.sleep(2) break else: #print(5) for t in templates5: template = image.Image(t) r = img.find_template(template, 0.70, step=4, search=SEARCH_EX) #, roi=(10, 0, 60, 60)) if r: img.draw_rectangle(r, color=0) str1="11" uart.write(str1+'\r\n') print(str1) time.sleep(2) break else: for t in templates6: template = image.Image(t) r = img.find_template(template, 0.70, step=4, search=SEARCH_EX) #, roi=(10, 0, 60, 60)) if r: img.draw_rectangle(r, color=0) str1="15" uart.write(str1+'\r\n') print(str1) time.sleep(2) break else: str1="99" uart.write(str1+'\r\n') time.sleep(2) break break break break break break
什么叫做卡住?具体的现象是什么。
@kidswong999 运行一会后,画面卡住,不再运行程序,数据不再传输
