  • 运行的时候显示IndexError:list index out of range 怎么解决?
      import sensor, image, time, math, lcd
      from pyb import LED
      LED(1).on()
      LED(2).on()
      LED(3).on()
      lcd.init()
      GRAYSCALE_THRESHOLD = [(0, 64)]
      ROIS = [ # [ROI, weight]
              (0, 100, 160, 20, 0.7), # You'll need to tweak the weights for you app
              (0, 050, 160, 20, 0.3), # depending on how your robot is setup.
              (0, 000, 160, 20, 0.1)
      weight_sum = 0 #权值和初始化
      for r in ROIS: weight_sum += r[4] # r[4] is the roi weight.
      sensor.set_pixformat(sensor.GRAYSCALE) # use grayscale.
      sensor.skip_frames(30,time = 2000) # Let new settings take affect.
      def send_frame(cx, cy):
          uart.writechar(0xA5)
          uart.writechar(0x5A)
          uart.writechar(cx)
          uart.writechar(cy)
          uart.writechar(cx + cy)
          centroid_sum = 0
          for r in ROIS:
              blobs = img.find_blobs(GRAYSCALE_THRESHOLD, roi=r[0:4], merge=True)
              # r[0:4] is roi tuple.
                  most_pixels = 0
                  largest_blob = 0
                  for i in range(len(blobs)):
                      if blobs[i].pixels() > most_pixels:
                          most_pixels = blobs[i].pixels()
                          largest_blob = i
                  img.draw_rectangle(blobs[largest_blob].rect())
                  img.draw_rectangle((0,0,30, 30))
                  #将此区域的像素数最大的颜色块画矩形和十字形标记出来
                  img.draw_cross(blobs[largest_blob].cx(),
                                 blobs[largest_blob].cy())
                  centroid_sum += blobs[largest_blob].cx() * r[4] # r[4] is the roi weight.
          center_pos = (centroid_sum / weight_sum) # Determine center of line.
          deflection_angle = 0
          deflection_angle = -math.atan((center_pos-80)/60)
          deflection_angle = math.degrees(deflection_angle)
          print("Turn Angle: %f" % deflection_angle)
          send_frame(blobs[largest_blob].cx(), blobs[largest_blob].cy())
          lcd.display(img)
    • 代码的逻辑有问题。
      如果没有找到色块,blobs[largest_blob].cx()就会错误。
