  • Openmv巡线程序问题
    • 本人在测试openmv巡线例程时,当摄像头视野范围内没有线时,程序就会死掉,请大神帮忙看一眼怎么改一下程序就没有线的时候程序也不崩溃。👏
    • @18800120366 # Fast Linear Regression Example
      This example shows off how to use the get_regression() method on your OpenMV Cam
      to get the linear regression of a ROI. Using this method you can easily build
      a robot which can track lines which all point in the same general direction
      but are not actually connected. Use find_blobs() on lines that are nicely
      connected for better filtering options and control.
      This is called the fast linear regression because we use the least-squares
      method to fit the line. However, this method is NOT GOOD FOR ANY images that
      have a lot (or really any) outlier points which corrupt the line fit...
      #设置阈值,(0,100)检测黑色线
      THRESHOLD = (0, 100) # Grayscale threshold for dark things...
      #设置是否使用img.binary()函数进行图像分割
      BINARY_VISIBLE = True # Does binary first so you can see what the linear regression
      # is being run on... might lower FPS though.
      uart = UART(3, 9600)
      sensor.skip_frames(100)
      time.sleep(1000)
      img = sensor.snapshot().binary([THRESHOLD]) if BINARY_VISIBLE else sensor.snapshot()
      time.sleep(100)
      line = img.get_regression([(255,255) if BINARY_VISIBLE else THRESHOLD])
      if (line): img.draw_line(line.line(), color = 127)
      print("FPS %f, mag = %s" % (clock.fps(), str(line.magnitude()) if (line) else "N/A"))
      print(line.theta())
      output_str="%03d"%(line.theta())
      time.sleep(300)
      uart.write(output_str)
      About negative rho values:
      A [theta+0:-rho] tuple is the same as [theta+180:+rho].
    • 怎么死掉的?具体的报错提示或者是现象?
