  • 保存特征点出现OSError:Failed to write requested bytes!
    • Keypoints descriptor example.
      This example shows how to save a keypoints descriptor to file. Show the camera an object
      and then run the script. The script will extract and save a keypoints descriptor and the image.
      You can use the keypoints_editor.py util to remove unwanted keypoints.
      NOTE: Please reset the camera after running this script to see the new file.
      import sensor, time, image
      Reset sensor
      Sensor settings
      sensor.set_contrast(3)
      FILE_NAME = "alphabet_A2"
      NOTE: See the docs for other arguments
      NOTE: By default find_keypoints returns multi-scale keypoints extracted from an image pyramid.
      A= img.find_keypoints(max_keypoints=150, threshold=10, scale_factor=1.2)
      if (A == None):
      raise(Exception("Couldn't find any keypoints!"))
      image.save_descriptor(A, "/%s.orb"%(FILE_NAME))
      img.save("/%s.pgm"%(FILE_NAME))
      img.draw_keypoints(A)
      sensor.snapshot()
      time.sleep(1000)
      raise(Exception("Done! Please reset the camera"))0_1565096881410_QQ图片20190806210744.png
