  • 在巡线的过程中同时录视频
    • sensor.reset() # Initialize the camera sensor.
          sensor.set_pixformat(sensor.GRAYSCALE) # use grayscale.
          sensor.set_framesize(sensor.QQQVGA) # use QVGA for speed. 80 * 60
          sensor.skip_frames(30) # Let new settings take affect.
          m = mjpeg.Mjpeg("why.mjpeg")
          for i in range(700):
          m.close(clock.fps())
          if Find_Line_ENABLE:
             All_Line = find_all_Line(img)
             Line_Info = line_info_process(All_Line)
             (Type,P0,P1,ang,flag) = RecognitionForm(ProcessImg(img),img)
             if Line_Info[0] == 0:
                  img.draw_circle(Line_Info[1],Line_Info[2], 3, color = 200, thickness = 2, fill = False)
             if All_Line:
                 for ii in All_Line:
                     img.draw_line(ii.line())
             green_led.on()
             red_led.on()
          pass
          if Find_ApriTag_ENABLE:
              (Type,P0,P1,ang) = Find_Apriltags(img)
              red_led.on()
          if Find_Circle_ENABLE:
              (Type,P0,P1,ang) = Find_Circle(img)
              green_led.on()
          print(Type,P0,P1,ang,flag)
          uart.write(UART_Send(Type,P0,P1,ang,flag))
      为什么录视频的同时不能出现框框的东西呢
    • 你要画完框之后,再m.add_frame(img)
