  • openmv传输数据总是一帧有数据,一帧没数据,有办法改善吗?
    • 和你的数据记录。
    • @kidswong999 没有出错
      请在这里粘贴代码import image, math, pyb, sensor, struct, time
      # P4 = TXD
      sensor.reset() #初始化相机传感器
      sensor.set_pixformat(sensor.GRAYSCALE) #设置相机模块的像素模式
      sensor.set_framesize(sensor.QQVGA) #设置相机模块的帧大小  设置采集到图片的分辨率
      sensor.skip_frames(30) #跳过30毫秒的帧
      f_y = (2.8 / 2.952) * 120 # 默认值
      c_x = 160 * 0.5 # 默认值(image.w * 0.5)
      c_y = 120 * 0.5 # 默认值(image.h * 0.5)
      def degrees(radians):
          clock.tick() #更新图像的帧率
          img = sensor.snapshot() #使用相机拍摄一张照片,并返回image对象
          for tag in img.find_apriltags(fx=f_x, fy=f_y, cx=c_x, cy=c_y): # 默认为TAG36H11
                 img.draw_rectangle(tag.rect(),color = (255, 0, 0))
                 img.draw_cross(tag.cx(), tag.cy(),color = (0, 255, 0))
                 print_args=(tag.id())
                 print_args = (tag.x_translation(), tag.y_translation(), tag.z_translation(), \
                     degrees(tag.x_rotation()), degrees(tag.y_rotation()), degrees(tag.z_rotation()))
                 #位置的单位是未知的,旋转的单位是角度
                 k1=18.867
                 k2=65.74
                 if tag.id()==1:
                     k=k1
                     k=k2
                 dx=int((k*tag.x_translation())/10)
                 dy=int((k*tag.y_translation())/10)
                 dz=int((k*tag.z_translation())/10)
                 print_output=(dx, dy, dz, \
      #print("Tx: %f, Ty %f, Tz %f, Rx %f, Ry %f, Rz %f" % print_args)
                 print('dx:%f,dy:%f,dz:%f,rx:%f,ry:%f,rz:%f'%print_output+'\n',tag.id())
                 send_data_packet_1()
                 cksum=checksum(temp_1)
                 send_data_packet_2()
              print(0)
      #k=实际距离/(根号(tx*tx+ty*ty+tz*tz))
      #实际tz=18.905172714*7.738752=146.302(150mm)
      结果是这样
      dx:3.000000,dy:-13.000001,dz:-30.000000,rx:183.992825,ry:0.241931,rz:199.244061
       1
      dx:3.000000,dy:-13.000001,dz:-30.000000,rx:183.765745,ry:357.644057,rz:198.377266
       1
      dx:3.000000,dy:-13.000001,dz:-30.000000,rx:181.203671,ry:356.643009,rz:198.084402
       1
      dx:3.000000,dy:-13.000001,dz:-30.000000,rx:184.328089,ry:356.393766,rz:198.164368
       1
      dx:3.000000,dy:-13.000001,dz:-30.000000,rx:180.400867,ry:356.212139,rz:198.021011
       1
      dx:3.000000,dy:-13.000001,dz:-30.000000,rx:182.285109,ry:355.715895,rz:197.918463
       1
      dx:3.000000,dy:-13.000001,dz:-30.000000,rx:183.995905,ry:355.844212,rz:198.019161
       1
      dx:3.000000,dy:-13.000001,dz:-30.000000,rx:182.665195,ry:356.893635,rz:198.217392
       1
      dx:3.000000,dy:-13.000001,dz:-30.000000,rx:181.986952,ry:354.710960,rz:197.725191
       1
      怎么让他连续都有输出呢?
    • 你的代码不全,我没办法运行。
    • @kidswong999
      # P4 = TXD
      uart = UART(3, 115200,timeout_char = 1000)
      #助降系统到飞控消息格式
      #1-2同步头 int16 EB90
      #3 工作状态
      #working_condition
      #4-5靶标跟踪误差X int16 像素
      tracking_error_X=0
      #6-7靶标跟踪误差Y int16 像素
      tracking_error_Y=0
      #标靶朝向 int16 0.01°
      The_target_toward=0
      #10-11相机俯仰角控制 int16 0.01°
      Camera_pitch_Angle=0
      #12-13相机方位角控制 int16 0.01°
      Camera_azimuth=0
      #14-15标靶北向速度 int16 cm/s
      Target_northbound_velocity=0
      #16-17标靶东向速度 int16 cm/s
      Target_eastbound_velocity=0
      #18-19标靶地向速度 int16 cm/s
      Target_ground_velocity=0
      #20-23标靶北向位置 int32 cm
      #dx
      #24-27标靶东向位置 int32 cm
      #dy
      #28-31标靶地向位置 int32 cm
      #dz
      #32-33标靶航向 uint16 0.01°
      The_target_course=0
      #34-35无人机航向角速度指令 int16 0.01°/s
      Uav_course_angular_velocity_command=0
      #36-37无人机前进速度指令 int16 0.01m/s
      Forward_speed_command=0
      #38-39无人机侧向速度指令 int16 0.01m/s
      Lateral_speed_command=0
      #40-41无人机垂向速度指令 int16 0.01m/s
      Vertical_speed_command=0
      #42校验和 uint8
      #checksum
      Uav_course_Angle=0
      #无人机航向角 int16  0.01°
      def recive_data():
          global  Uav_course_Angle
          if uart.any():
              recive=uart.read()
              recive_1=struct.unpack("bbbhhhhhHhhhiiibhhhiiib",recive)
              Uav_course_Angle=recive_1[5]
          return  Uav_course_Angle
      def send_data_packet_1():
          global temp_1
          temp_1 = struct.pack("bbbhhhhhhhhiiihhhhh",
                             0xEB,
                             0x90,
                             working_condition,
                             tracking_error_X,
                             tracking_error_Y,
                             The_target_toward,
                             Camera_pitch_Angle,
                             Camera_azimuth,
                             Target_northbound_velocity,
                             Target_eastbound_velocity,
                             Target_ground_velocity,
                             dx,
                             dy,
                             dz,
                             The_target_course,
                             Uav_course_angular_velocity_command,
                             Forward_speed_command,
                             Lateral_speed_command,
                             Vertical_speed_command)
      def checksum(data):
          output=0x00
          for i in range(len(data)):
               output+=data[i]
          cksum_1=output%0x100
          return cksum_1
      cksum=0x00
      def send_data_packet_2():
          global temp_2
          temp_2 = struct.pack("bbbhhhhhhhhiiihhhhhb",
                             0xEB,
                             0x90,
                             working_condition,
                             tracking_error_X,
                             tracking_error_Y,
                             The_target_toward,
                             Camera_pitch_Angle,
                             Camera_azimuth,
                             dx,
                             dy,
                             dz,
                             The_target_course,
                             Vertical_speed_command,
                             cksum)
          uart.write(temp_2)
      #def send_data_packet(x,y):
          #temp=struct.pack("<bbii",  #格式为两个字符两个整形
                      #0xAA,          #帧头1
                      #0xAE,          #帧头2
                      #int(x),        #数据1
                      #int(y)         #数据2
          #uart.write(temp)           #串口发送
      # f_x 是x的像素为单位的焦距。对于标准的OpenMV,应该等于2.8/3.984*656,这个值是用毫米为单位的焦距除以x方向的感光元件的长度,乘以x方向的感光元件的像素(OV7725)
      # f_y 是y的像素为单位的焦距。对于标准的OpenMV,应该等于2.8/2.952*488,这个值是用毫米为单位的焦距除以y方向的感光元件的长度,乘以y方向的感光元件的像素(OV7725)
      # c_x 是图像的x中心位置
      # c_y 是图像的y中心位置
      #kz=实际距离/Tz
      #20cm处,kz=200mm/6.85=29.197
      #tz=9.89
      #实际=kz*tz=9.89*200/6.85=288.759mm
          clock.tick() #开始追踪运行时间
                 # 位置的单位是未知的,旋转的单位是角度
              k1=18.867
              k2=65.74
              if tag.id()==1:
                  k=k1
                  k=k2
              #print('dx:%f,dy:%f,dz:%f,rx:%f,ry:%f,rz:%f'%print_output+'\n',tag.id())
              working_condition=2
              print(temp_2)
              print(0)
              dx=0
              dy=0
              dz=0
              working_condition=0
      是希望它能连续的拍到并输出,但是总是一帧能拍到一帧拍不到
      b'\xeb\x90\x02\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\xf4\xff\xff\xff\x04\x00\x00\x00\xe3\xff\xff\xff\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00R'
      b'\xeb\x90\x02\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\xf4\xff\xff\xff\x04\x00\x00\x00\xe4\xff\xff\xff\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00S'
      b'\xeb\x90\x02\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\xf3\xff\xff\xff\x04\x00\x00\x00\xe3\xff\xff\xff\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00Q'
      b'\xeb\x90\x02\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\xf3\xff\xff\xff\x05\x00\x00\x00\xe3\xff\xff\xff\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00R'
