openmv传输数据总是一帧有数据,一帧没数据,有办法改善吗?
和你的数据记录。
@kidswong999 没有出错
请在这里粘贴代码import image, math, pyb, sensor, struct, time from pyb import UART # P4 = TXD sensor.reset() #初始化相机传感器 sensor.set_pixformat(sensor.GRAYSCALE) #设置相机模块的像素模式 sensor.set_framesize(sensor.QQVGA) #设置相机模块的帧大小 设置采集到图片的分辨率 sensor.skip_frames(30) #跳过30毫秒的帧 f_x = (2.8 / 3.984) * 160 # 默认值 f_y = (2.8 / 2.952) * 120 # 默认值 c_x = 160 * 0.5 # 默认值(image.w * 0.5) c_y = 120 * 0.5 # 默认值(image.h * 0.5) def degrees(radians): return (180 * radians) / math.pi clock = time.clock() while(True): clock.tick() #更新图像的帧率 img = sensor.snapshot() #使用相机拍摄一张照片,并返回image对象 for tag in img.find_apriltags(fx=f_x, fy=f_y, cx=c_x, cy=c_y): # 默认为TAG36H11 img.draw_rectangle(tag.rect(),color = (255, 0, 0)) img.draw_cross(tag.cx(), tag.cy(),color = (0, 255, 0)) print_args=(tag.id()) print_args = (tag.x_translation(), tag.y_translation(), tag.z_translation(), \ degrees(tag.x_rotation()), degrees(tag.y_rotation()), degrees(tag.z_rotation())) #位置的单位是未知的,旋转的单位是角度 k1=18.867 k2=65.74 if tag.id()==1: k=k1 else: k=k2 dx=int((k*tag.x_translation())/10) dy=int((k*tag.y_translation())/10) dz=int((k*tag.z_translation())/10) print_output=(dx, dy, dz, \ degrees(tag.x_rotation()), degrees(tag.y_rotation()), degrees(tag.z_rotation())) #print("Tx: %f, Ty %f, Tz %f, Rx %f, Ry %f, Rz %f" % print_args) #print("Tx: %f, Ty %f, Tz %f, Rx %f, Ry %f, Rz %f" % print_args) print('dx:%f,dy:%f,dz:%f,rx:%f,ry:%f,rz:%f'%print_output+'\n',tag.id()) send_data_packet_1() cksum=checksum(temp_1) send_data_packet_2() else: print(0) #k=实际距离/(根号(tx*tx+ty*ty+tz*tz)) #实际tz=18.905172714*7.738752=146.302(150mm)
结果是这样
dx:3.000000,dy:-13.000001,dz:-30.000000,rx:183.992825,ry:0.241931,rz:199.244061 1 0 dx:3.000000,dy:-13.000001,dz:-30.000000,rx:183.765745,ry:357.644057,rz:198.377266 1 0 dx:3.000000,dy:-13.000001,dz:-30.000000,rx:181.203671,ry:356.643009,rz:198.084402 1 0 dx:3.000000,dy:-13.000001,dz:-30.000000,rx:184.328089,ry:356.393766,rz:198.164368 1 0 dx:3.000000,dy:-13.000001,dz:-30.000000,rx:180.400867,ry:356.212139,rz:198.021011 1 0 dx:3.000000,dy:-13.000001,dz:-30.000000,rx:182.285109,ry:355.715895,rz:197.918463 1 0 dx:3.000000,dy:-13.000001,dz:-30.000000,rx:183.995905,ry:355.844212,rz:198.019161 1 0 dx:3.000000,dy:-13.000001,dz:-30.000000,rx:182.665195,ry:356.893635,rz:198.217392 1 0 dx:3.000000,dy:-13.000001,dz:-30.000000,rx:181.986952,ry:354.710960,rz:197.725191 1 0
怎么让他连续都有输出呢?
你的代码不全,我没办法运行。
import image, math, pyb, sensor, struct, time from pyb import UART # P4 = TXD sensor.reset() #初始化相机传感器 sensor.set_pixformat(sensor.GRAYSCALE) #设置相机模块的像素模式 sensor.set_framesize(sensor.QQVGA) #设置相机模块的帧大小 sensor.skip_frames(30) #跳过30毫秒的帧 uart = UART(3, 115200,timeout_char = 1000) #助降系统到飞控消息格式 #1-2同步头 int16 EB90 #3 工作状态 #working_condition #4-5靶标跟踪误差X int16 像素 tracking_error_X=0 #6-7靶标跟踪误差Y int16 像素 tracking_error_Y=0 #标靶朝向 int16 0.01° The_target_toward=0 #10-11相机俯仰角控制 int16 0.01° Camera_pitch_Angle=0 #12-13相机方位角控制 int16 0.01° Camera_azimuth=0 #14-15标靶北向速度 int16 cm/s Target_northbound_velocity=0 #16-17标靶东向速度 int16 cm/s Target_eastbound_velocity=0 #18-19标靶地向速度 int16 cm/s Target_ground_velocity=0 #20-23标靶北向位置 int32 cm #dx #24-27标靶东向位置 int32 cm #dy #28-31标靶地向位置 int32 cm #dz #32-33标靶航向 uint16 0.01° The_target_course=0 #34-35无人机航向角速度指令 int16 0.01°/s Uav_course_angular_velocity_command=0 #36-37无人机前进速度指令 int16 0.01m/s Forward_speed_command=0 #38-39无人机侧向速度指令 int16 0.01m/s Lateral_speed_command=0 #40-41无人机垂向速度指令 int16 0.01m/s Vertical_speed_command=0 #42校验和 uint8 #checksum Uav_course_Angle=0 #无人机航向角 int16 0.01° def recive_data(): global Uav_course_Angle if uart.any(): recive=uart.read() recive_1=struct.unpack("bbbhhhhhHhhhiiibhhhiiib",recive) Uav_course_Angle=recive_1[5] return Uav_course_Angle def send_data_packet_1(): global temp_1 temp_1 = struct.pack("bbbhhhhhhhhiiihhhhh", 0xEB, 0x90, working_condition, tracking_error_X, tracking_error_Y, The_target_toward, Camera_pitch_Angle, Camera_azimuth, Target_northbound_velocity, Target_eastbound_velocity, Target_ground_velocity, dx, dy, dz, The_target_course, Uav_course_angular_velocity_command, Forward_speed_command, Lateral_speed_command, Vertical_speed_command) def checksum(data): output=0x00 for i in range(len(data)): output+=data[i] cksum_1=output%0x100 return cksum_1 cksum=0x00 def send_data_packet_2(): global temp_2 temp_2 = struct.pack("bbbhhhhhhhhiiihhhhhb", 0xEB, 0x90, working_condition, tracking_error_X, tracking_error_Y, The_target_toward, Camera_pitch_Angle, Camera_azimuth, Target_northbound_velocity, Target_eastbound_velocity, Target_ground_velocity, dx, dy, dz, The_target_course, Uav_course_angular_velocity_command, Forward_speed_command, Lateral_speed_command, Vertical_speed_command, cksum) uart.write(temp_2) #def send_data_packet(x,y): #temp=struct.pack("<bbii", #格式为两个字符两个整形 #0xAA, #帧头1 #0xAE, #帧头2 #int(x), #数据1 #int(y) #数据2 #uart.write(temp) #串口发送 # f_x 是x的像素为单位的焦距。对于标准的OpenMV,应该等于2.8/3.984*656,这个值是用毫米为单位的焦距除以x方向的感光元件的长度,乘以x方向的感光元件的像素(OV7725) # f_y 是y的像素为单位的焦距。对于标准的OpenMV,应该等于2.8/2.952*488,这个值是用毫米为单位的焦距除以y方向的感光元件的长度,乘以y方向的感光元件的像素(OV7725) # c_x 是图像的x中心位置 # c_y 是图像的y中心位置 #kz=实际距离/Tz #20cm处,kz=200mm/6.85=29.197 #tz=9.89 #实际=kz*tz=9.89*200/6.85=288.759mm f_x = (2.8 / 3.984) * 160 # 默认值 f_y = (2.8 / 2.952) * 120 # 默认值 c_x = 160 * 0.5 # 默认值(image.w * 0.5) c_y = 120 * 0.5 # 默认值(image.h * 0.5) def degrees(radians): return (180 * radians) / math.pi clock = time.clock() while(True): clock.tick() #开始追踪运行时间 img = sensor.snapshot() #使用相机拍摄一张照片,并返回image对象 for tag in img.find_apriltags(fx=f_x, fy=f_y, cx=c_x, cy=c_y): # 默认为TAG36H11 img.draw_rectangle(tag.rect(),color = (255, 0, 0)) img.draw_cross(tag.cx(), tag.cy(),color = (0, 255, 0)) print_args=(tag.id()) print_args = (tag.x_translation(), tag.y_translation(), tag.z_translation(), \ degrees(tag.x_rotation()), degrees(tag.y_rotation()), degrees(tag.z_rotation())) # 位置的单位是未知的,旋转的单位是角度 k1=18.867 k2=65.74 if tag.id()==1: k=k1 else: k=k2 dx=int((k*tag.x_translation())/10) dy=int((k*tag.y_translation())/10) dz=int((k*tag.z_translation())/10) print_output=(dx, dy, dz, \ degrees(tag.x_rotation()), degrees(tag.y_rotation()), degrees(tag.z_rotation())) #print("Tx: %f, Ty %f, Tz %f, Rx %f, Ry %f, Rz %f" % print_args) #print('dx:%f,dy:%f,dz:%f,rx:%f,ry:%f,rz:%f'%print_output+'\n',tag.id()) working_condition=2 send_data_packet_1() cksum=checksum(temp_1) send_data_packet_2() print(temp_2) else: print(0) dx=0 dy=0 dz=0 working_condition=0 send_data_packet_1() cksum=checksum(temp_1) send_data_packet_2() #k=实际距离/(根号(tx*tx+ty*ty+tz*tz)) #实际tz=18.905172714*7.738752=146.302(150mm)
是希望它能连续的拍到并输出,但是总是一帧能拍到一帧拍不到
b'\xeb\x90\x02\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\xf4\xff\xff\xff\x04\x00\x00\x00\xe3\xff\xff\xff\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00R' 0 b'\xeb\x90\x02\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\xf4\xff\xff\xff\x04\x00\x00\x00\xe3\xff\xff\xff\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00R' 0 b'\xeb\x90\x02\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\xf4\xff\xff\xff\x04\x00\x00\x00\xe4\xff\xff\xff\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00S' 0 b'\xeb\x90\x02\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\xf4\xff\xff\xff\x04\x00\x00\x00\xe3\xff\xff\xff\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00R' 0 b'\xeb\x90\x02\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\xf3\xff\xff\xff\x04\x00\x00\x00\xe3\xff\xff\xff\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00Q' 0 b'\xeb\x90\x02\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\xf3\xff\xff\xff\x05\x00\x00\x00\xe3\xff\xff\xff\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00R' 0 b'\xeb\x90\x02\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\xf4\xff\xff\xff\x04\x00\x00\x00\xe3\xff\xff\xff\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00R' 0
