  • 一个物体需要满足,是矩形和满足设置的颜色阈值这两个条件才会被识别出来,if语句应该怎么写?
      K=660#the value should be measured
      yellow_threshold   = (9, 62, 9, 65, -80, -7)
              if blob.pixels() > max_size:
                  max_size = blob.pixels()
          sensor.set_hmirror(False) #水平方向翻转
          sensor.set_vflip(False) #垂直方向翻转
          #if not blobs:
          for r in img.find_rects(threshold = 30000):
              area = (r.x(),r.y(),r.w(),r.h())
              for p in r.corners():
                  img.draw_circle(p[0], p[1], 5, color = (0, 255, 0))
        #  for c in img.find_circles(threshold = 3500, x_margin = 10, y_margin = 10, r_margin = 10,
         #     r_min = 2, r_max = 100, r_step = 2):
              print (r)
              #area为识别到的圆的区域,即圆的外接矩形框
              #print(statistics)
              #(94, 100, -128, 127, -128, 127)是红色的阈值,所以当区域内的众数(也就是最多的颜色),范围在这个阈值内,就说明是红色的圆。
              if 56<statistics.l_mode()<79 and 35<statistics.a_mode()<127 and -128<statistics.b_mode()<127:#if the circle is red
                  img.draw_rectangle(area, color = (255, 255, 255))
                  #将非红色的圆用白色的矩形框出来
          if blobs :#and len(blobs)==1 :就是这里应该怎么改!!!!!!!!!!!!!!
              max_blob=find_max(blobs)
              output_str="[%d,%d]\n" % (max_blob.cx(),max_blob.cy()) #方式1
              print('you send:',output_str)
              b = blobs[0]
              Lm = (b[2]+b[3])/2
              length = K/Lm
                      #print(Lm)
              print(length)
      怎么设置找到我要的颜色阈值并且该物体是矩形,就是一个物体需要满足,是矩形和是我设置的颜色阈值这两个条件才会被识别出来,所以if语句应该怎么写
