  • openmv什么时候可以使用VGA模式?
    • 我在把颜色识别和形状识别结合在一起的时候,发现可能是像素点太少的缘故,当距离较远或者角度不正的时候,会识别失败,所以想把QQVGA换成VGA,但是它会报错如下,有人知道怎么才能使用VGA模式吗?我用的7725v3和stm32H7芯片,所以不用担心处理速度的问题。
      color_threshold1 = (0, 255, 40, 80, 40, 70)
      color_threshold2 = (0, 130, 40, 80, 40, 70)
      sensor.set_framesize(sensor.QQVGA) # use QVGA for quailtiy ,use QQVGA for speed.
      #扩宽roi
      def expand_roi(roi):
          # set for QQVGA 160*120
          extra = 5
          win_size = (160, 120)
          (x, y, width, height) = roi
          new_roi = [x-extra, y-extra, width+2*extra, height+2*extra]
          if new_roi[0] < 0:
              new_roi[0] = 0
          if new_roi[1] < 0:
              new_roi[1] = 0
          if new_roi[2] > win_size[0]:
              new_roi[2] = win_size[0]
          if new_roi[3] > win_size[1]:
              new_roi[3] = win_size[1]
          return tuple(new_roi)
          #  pixels_threshold=100, area_threshold=100
          blobs = img.find_blobs([color_threshold1], area_threshold=150)
          #如果找到了目标颜色
              print(blobs)
              #迭代找到的目标颜色区域
                  is_rect = 0
                  rect_s=0
                  max_s = -1
                  new_roi = expand_roi(blob.rect())
                  for c in img.find_rects():
                      is_rect = 1
                      rect_s=c.y()*c.h()
                      # img.draw_rectangle(x,y,w,h [,color[,thickness=1[,fill=False]]])
                      if rect_s > max_s:
                          max_s = rect_s
                          max_rect = c
                  if is_rect:
                      # 如果有对应颜色的矩形 标记外框
                      img.draw_rectangle(new_roi) # rect
                      img.draw_rectangle(blob.rect()) # rect
                      #用矩形标记出目标颜色区域
                      img.draw_cross(blob[5], blob[6]) # cx, cy
                      img.draw_rectangle(max_rect.x(), max_rect.y(), max_rect.w(),  max_rect.h(),color = (0, 255, 0))
                      img.draw_rectangle(max_rect.x()-1, max_rect.y()-1, max_rect.w()+2,  max_rect.h()+2,color = (0, 255, 0))
      ![0_1563880779720_1.PNG](https://fcdn.singtown.com/55dd819e-826d-4e91-a4ac-083e8576c64b.PNG)
    • VGA模式下是压缩图像,不能进行算法处理。
    • @kidswong999 嗯,多谢解惑呀
    • 能不能识别多种颜色然后同时画框
    • @egxs 不同的问题,单独发帖子。
