色块可以成功识别,但print不出我想要的数据,请问一下下面这段代码哪里有问题呢?
# Untitled - By: HP - 周五 6月 7 2019 import sensor,time,pyb,math,image import json from pyb import Pin,Timer,LED,UART uart_buf =bytearray([0x55,0x00,0x00,0x00,0x00,0xAA]) #设置发送串口3 uart = UART(3,9600) uart.init(9600,bits=8,parity=None,stop=1) x_error =0 y_error =0 x_Sign = 0 y_Sign = 0 def find_max(blobs): #寻找最大色块函数定义 max_pixels=0 #通过像素比较 for blob in blobs: #blob[0,1,2,3,4]=x,y,w,h,pixels (int) if blob[4]>max_pixels: max_blob=blob max_pixels=blob[4] return max_blob sensor.reset() sensor.set_pixformat(sensor.RGB565) sensor.set_framesize(sensor.QQVGA) # we run out of memory if the resolution is much bigger... 图像像素大小QQVGA是160✖120 sensor.skip_frames(30) sensor.set_auto_gain(False) # must turn this off to prevent image washout... sensor.set_auto_whitebal(False) # must turn this off to prevent image washout... sensor.set_auto_exposure(True) clock = time.clock() black = (0, 31, -34, 41, 24, -21) while(True): clock.tick() img=sensor.snapshot() blobs = img.find_blobs([black]) if blobs: max_blob=find_max(blobs) img.draw_rectangle(max_blob.rect()) img.draw_cross(max_blob.cx(),max_blob.cy()) x_error = int(max_blob.cx()-img.width()/2) y_error = int(max_blob.cy()-img.height()/2) else: x_error = 0 y_error = 0 if x_error >= 0: x_Sign = 0 if x_error <=0: x_Sign = 1 if y_error >= 0: y_Sign = 0 if y_error <= 0: y_Sign = 1 x_abs=abs(x_error) y_abs=abs(y_error) print(x_Sign,x_abs,y_Sign,y_abs)
缩进不对,导致逻辑不对。
嗯嗯嗯嗯解决啦,感谢!
