  • 如何在色块识别的框的范围内进行颜色替换?
    • 2_1560836694881_QQ截图20190618134312.png 1_1560836694880_QQ截图20190618134305.png 0_1560836694878_QQ截图20190618134252.png
      思路是先识别色块,然后在框内进行flood_fill的操作
      我想完成图1的效果,但是经常出现图2图3的样子
      我试过将flood_fill的(x,y)替换成色块识别的中心点,但是这样就没法填充了
      以下是代码:
      # 洪水填充
      # 此示例显示图像中的洪水填充区域。
      sensor.set_pixformat(sensor.RGB565) # or GRAYSCALE...
      sensor.set_framesize(sensor.QVGA) # or QQVGA...
      sensor.set_auto_whitebal(False);
      print("Learning thresholds...")
      threshold = (58, 91, 20, 60, -15, 18)
              if blob[2]*blob[3]>max_size:
                  max_size=blob[2]*blob[3]
          # seed_threshold controls the maximum allowed difference between
          # the initial pixel and any filled pixels. It's important to
          # set this such that flood fill doesn't fill the whole image.
          # floating_threshold controls the maximum allowed difference
          # between any two pixels. This can easily fill the whole image
          # with even a very low threshold.
          # flood_fill will fill pixels that both thresholds.
          # You can invert what gets filled with "invert" and clear
          # everything but the filled area with "clear_background".
          #从中心点开始寻找,(x,y)即为Initial pixel
          x = sensor.width()//2
          y = sensor.height()//2
          img = sensor.snapshot()#从摄像头snapshot图像
          blobs=img.find_blobs([threshold], pixels_threshold=100, area_threshold=100, merge=True, margin=10)
              #寻找最大物体
              max_blob=find_max(blobs)
              #设定ROI范围为最大物体的框
              roi=img.draw_rectangle(max_blob.rect())
              #在框中心点画十字
              #x=max_blob.cx()
              #y=max_blob.cy()
              #在ROI中进行填充
              roi.flood_fill(x, y, seed_threshold=0.2, floating_thresholds=1, color=(255, 255, 0), invert=False, clear_background=False)
    • max_blob=find_max(blobs)
      img.flood_fill(max_blob.cx(), max_blob.cy(), seed_threshold=0.2, floating_thresholds=1, color=(255, 255, 0), invert=False, clear_background=False)
    • @kidswong999如何在色块识别的框的范围内进行颜色替换? 中说:
      这我也试过了,这样就只有中心点是一个黄色的点,我是想把整个红色瓶盖换成别的颜色
    • img.flood_fill要在你画线画框函数的上面。看我的代码。
      搞定,谢谢
