自动增益为什么有时候会失效
用的是这个函数sensor.set_auto_gain(False)
enable_lens_corr = False # turn on for straighter lines...
clock = time.clock()min_degree = 0
max_degree = 179while(True):
if enable_lens_corr: img.lens_corr(1.8) # for 2.8mm lens...for l in img.find_lines(threshold = 1000, theta_margin = 30, rho_margin = 30): if (min_degree <= l.theta()) and (l.theta() <= max_degree): img.draw_line(l.line(), color = (255, 0, 0)) print(l) print("FPS %f" % clock.fps())
你要把set_auto_gain放到reset下面,否则reset会重置所有的设置。
而且最好放到2s延迟后面。sensor.reset() sensor.set_pixformat(sensor.RGB565) # grayscale is faster sensor.set_framesize(sensor.QQVGA) sensor.skip_frames(time = 2000) sensor.set_auto_gain(False)
@kidswong999 谢谢!
@kidswong999 在 自动增益为什么有时候会失效 中说:
