  • openmv串口检测到数据
      uart = UART(3, 19200)
      uart.init(4800, bits=8, parity=None, stop=1, timeout_char=1000)
      target_threshold   = (58, 76, -13, 8, -84, 70)
      ball_threshold =(58, 76, -13, 8, -84, 70)#待修改
      sensor.skip_frames(10)
      def find_c(threshold,roi):
           number=0
           blobs = img.find_blobs(threshold,roi=roi,x_stride=10, y_stride=50)
           for b in blobs:
               if b[2]*b[3] > max_size:
                   max_size = b[2]*b[3]
                   if max_size>2000:
                       max_size=max_size
                       img.draw_rectangle(b[0:4], color = (0, 0, 0))
                       img.draw_cross(b[5], b[6], color = (0, 0, 0))
                       number=b[5]
           return number
      def delay(a):  #对画面进行延迟,不影响ide中的画面流畅度
          b=0
          for i in range(20):
              sensor.snapshot()
              if i == 18:
                  b=a
          return b
      def delay1(a):#对画面进行延迟,不影响ide中的画面流畅度,并对串口发送数据进行延迟
          for i in range(20):
              sensor.snapshot()
              if i == 18:
                  output_str=json.dumps(a)
                  uart.write(output_str+'\r\n')
      def average_zhi(num,n):
          sum=0
          a=[]
          i=0
          if num:
              a.append(num)
              i=i+1
              if i==n-1:
                  a.sort()
                  for i in a[1,b-1]:
                      sum=sum+i
                      c=b-2
                      sum=int(sum/c)
          return sum
          roi1=[0,0,70,60]
          roi2=[90,0,60,60]
          roi_ball=[0,0,160,60]#待修改
          blobs1 = img.find_blobs([target_threshold],roi=roi1,x_stride=10, y_stride=50)
          blobs2 = img.find_blobs([target_threshold],roi=roi2,x_stride=10, y_stride=50)
          blobs_blob = img.find_blobs([ball_threshold],roi=roi_ball)
          if blobs1 and blobs2:
              first_number=find_c([target_threshold],roi1)
              second_number=find_c([target_threshold],roi2)
              average_number=(first_number+second_number)/2
              average_number=int(average_number)
              if 60<average_number<100 and first_number and second_number:
                   average=average_zhi(average_number,10)
                   #delay1(average_number)
                   #if average
                   print(average_number)
                   #uart.write('1')
              # time.sleep(1500)
          '''uart.write('2')
          time.sleep(1500)
          uart.write('3')
          time.sleep(1500)
          uart.write('4g')
          time.sleep(1500)'''
      这是代码
      openmv串口检测到数据,现在为了确保数据的稳定性,我想把十个数放到一个数组中,然后通过串口向单片机发送,我写好时候为什么只返回0,并没有我想要的坐标值
    • @3icr 我的这个函数为什么一直返回零
          sum=0
          a=[]
          i=0
          if num:
              a.append(num)
              i=i+1
              if i==n-1:
                  a.sort()
                  for i in a[1,b-1]:
                      sum=sum+i
                      c=b-2
                      sum=int(sum/c)
          return sum
    • 我不知道你的函数为什么错了,我没法检查。
    • @kidswong999 def average_zhi(num,n):
      sum=0
      a=[]
      i=0
      if num:
      a.append(num)
      i=i+1
      if i==n-1:
      a.sort()
      for i in a[1,b-1]:
      sum=sum+i
      c=b-2
      sum=int(sum/c)
      return sum
      这个函数为什么一直返回零
