星瞳实验室APP,快速收到回复
  • 请问为何在电脑上可以运行,脱机运行就无法连接wifi?
    • # MJPEG Streaming AP.
      # This example shows off how to do MJPEG streaming in AccessPoint mode.
      # Chrome, Firefox and MJpegViewer App on Android have been tested.
      # Connect to OPENMV_AP and use this URL: http://192.168.1.1:8080 to view the stream.
      # Reset sensor
      # Set sensor settings
      sensor.set_brightness(1)
      sensor.set_saturation(1)
      # Init wlan module in AP mode.
      # Load Haar Cascade
      print(face_cascade)
      # You can block waiting for client to connect
      def start_streaming(s):
          client, addr = s.accept()
          client.settimeout(2.0)
          # Read request from client
          data = client.recv(1024)
          # Send multipart header
                      "Server: OpenMV\r\n" \
                      "Pragma: no-cache\r\n\r\n")
          # FPS clock
          # Start streaming images
              frame = sensor.snapshot()
              header = "\r\n--openmv\r\n" \
              client.send(header)
              client.send(cframe)
              #print(clock.fps())
              # Find objects.
              #image.find_features(cascade, threshold=0.5, scale=1.5),thresholds越大,
              #匹配速度越快,错误率也会上升。scale可以缩放被匹配特征的大小。
              #在找到的目标上画框,标记出来
              # Draw objects
              for r in objects:
                  img.draw_rectangle(r)
              # Print FPS.
              # Note: Actual FPS is higher, streaming the FB makes it slower.
              #print(clock.fps())
              if objects:
                  middle = int((objects[0][0]+objects[0][2])/2)
                  print(middle)
                  print('no')
      #clock = time.clock()
          # Create server socket
              # Bind and listen
              s.bind([HOST, PORT])
              s.listen(5)
              # Set server socket timeout
              s.settimeout(3)
              start_streaming(s)
          except OSError as e:
              s.close()
              print("socket error: ", e)
              #sys.print_exception(e)
    • 这是我写的代码,而且人脸识别的识别精度比例程差了许多,请问原因?
    • @19805185968 不同的问题单独发帖子。
    • @kidswong999 好的,但请先把WIFI无法脱机运行的的问题解决一下好吗,上面是代码
    • 我现在在外地,等回去拿到Wi-Fi扩展板测试一下。
    • OpenMV的wifi扩展板当作热点时,只能连接一个设备。
      你是不是既连了手机,还要连接电脑?
    • @kidswong999 并没有,电脑端并没有连接OPENMV的热点,还有就是使用5V电源直接供电OPENMV灯明显闪烁的不对,手机上也搜不到热点,我是使用充电宝供电才出现热点,但无法连接!
