星瞳实验室APP,快速收到回复
  • 定时器调用出现报错,IDE获取的画面停止,模块与电脑断开
    • 之前发现这个问题,但是没得到解决
      from pyb import Pin, Timer
      RUN = LED(4)
      def tick(timer):            # we will receive the timer object when being called
          RUN.toggle()
      tim = Timer(4, freq=1)      # create a timer object using timer 4 - trigger at 1Hz
      tim.callback(tick)          # set the callback to our tick function
      LED未定义。
