代码出什么问题了吗?为什么在ide里运行是就卡住了呢?但是没有报错
# This example shows off single color RGB565 tracking using the OpenMV Cam. import sensor, image, time import time from pyb import DAC dac = DAC("P6") threshold_index = 0 # 0 for red, 1 for green, 2 for blue ## Color Tracking Thresholds (L Min, L Max, A Min, A Max, B Min, B Max) ## The below thresholds track in general red/green/blue things. You may wish to tune them... thresholds = [(30, 100, 15, 127, 15, 127), # generic_red_thresholds (30, 100, -64, -8, -32, 32), # generic_green_thresholds (0, 30, 0, 64, -128, 0)] # generic_blue_thresholds sensor.reset() sensor.set_pixformat(sensor.RGB565) sensor.set_framesize(sensor.QVGA) sensor.skip_frames(time = 2000) sensor.set_auto_gain(False) # must be turned off for color tracking sensor.set_auto_whitebal(False) # must be turned off for color tracking clock = time.clock() ## Only blobs that with more pixels than "pixel_threshold" and more area than "area_threshold" are ## returned by "find_blobs" below. Change "pixels_threshold" and "area_threshold" if you change the ## camera resolution. "merge=True" merges all overlapping blobs in the image. while(True): clock.tick() img = sensor.snapshot() for blob in img.find_blobs([thresholds[threshold_index]], pixels_threshold=200, area_threshold=200, merge=True): img.draw_rectangle(blob.rect()) img.draw_cross(blob.cx(), blob.cy()) #print(clock.fps()) #import time #from pyb import DAC #dac = DAC("P6") while(True): #for i in range(256): dac.write(255) #time.sleep(20) #for i in range(256): #dac.write(255-i) #time.sleep(20)
没有卡住,因为你的死循环里又套了一个死循环,你看不到现象而已。
@kidswong999 如何破解呢?您应该可以看出来我想做一个识别颜色后输出模拟信号的程序
