  • 代码出什么问题了吗?为什么在ide里运行是就卡住了呢?但是没有报错
    • # This example shows off single color RGB565 tracking using the OpenMV Cam.
      from pyb import DAC
      dac = DAC("P6")
      threshold_index = 0 # 0 for red, 1 for green, 2 for blue
      ## Color Tracking Thresholds (L Min, L Max, A Min, A Max, B Min, B Max)
      ## The below thresholds track in general red/green/blue things. You may wish to tune them...
                    (0, 30, 0, 64, -128, 0)] # generic_blue_thresholds
      ## Only blobs that with more pixels than "pixel_threshold" and more area than "area_threshold" are
      ## returned by "find_blobs" below. Change "pixels_threshold" and "area_threshold" if you change the
      ## camera resolution. "merge=True" merges all overlapping blobs in the image.
          for blob in img.find_blobs([thresholds[threshold_index]], pixels_threshold=200, area_threshold=200, merge=True):
          #print(clock.fps())
      #import time
      #from pyb import DAC
      #dac = DAC("P6")
          #for i in range(256):
              dac.write(255)
              #time.sleep(20)
              #dac.write(255-i)
              #time.sleep(20)
    • 没有卡住,因为你的死循环里又套了一个死循环,你看不到现象而已。
    • @kidswong999 如何破解呢?您应该可以看出来我想做一个识别颜色后输出模拟信号的程序
