代码识别一次或者两次过后,openmv进行卡屏,只能拔电重启摄像头,请问这是怎么回事?
import sensor, image,time,lcd from pyb import UART,Timer,LED sensor.reset() sensor.set_pixformat(sensor.RGB565) sensor.set_framesize(sensor.QVGA)#320*240 sensor.set_framesize(sensor.VGA) sensor.set_windowing((240, 240)) sensor.skip_frames(30) sensor.set_auto_whitebal(False) #关闭白平衡 sensor.set_auto_gain(False) #关闭自动增益 clock = time.clock() lcd.init() #Initialize the lcd screen. uart = UART(3,115200,8,None,1) #创建串口对象 data = [] buff=[0,0,0,0,0,0,0,0] LED_Red = LED(1) LED_Green = LED(2) LED_Blue = LED(3) tim = Timer(4,freq=1) # create a timer object using timer 4 #tim.callback(tick) tim.deinit() FlagOK = 0 show_numTab = ["0","1","2","3","4","5","6","7","8","9"] num = 0 returnData = [0x55,0x02,0x92,0x02,0x02,0x00,0x00,0xBB] #识别失败 runData = [0x55,0x02,0x92,0x03,0x02,0x00,0x00,0xBB] #正在识别 #定时器回调函数 def tick(timer): # we will receive the timer object when being called global FlagOK,num,returnData print("Timer callback") num = num-1 if(num == 0): num = 9 FlagOK = 2 tim.deinit() #串口发送函数 def USART_Send(src,length): for i in range(length): uart.writechar(src[i]) # 二维码识别,并返回识别结果 def Color_Check(srcbuf): global FlagOK,num if(FlagOK == 1): img.draw_string(100, 180,"open"+show_numTab[num],color=[255,0,0]) for code in img.find_qrcodes(): FlagOK = 0 tim.deinit() print(code) qr_Tab = code.payload() uart.writechar(0x55) uart.writechar(0x02) uart.writechar(0x92) uart.writechar(0x01) uart.writechar(len(qr_Tab)) for qrdata in qr_Tab: uart.writechar(ord(qrdata)) uart.writechar(0xBB) if(FlagOK == 2): for rdata in returnData: uart.writechar(rdata) FlagOK = 0 while(True): img = sensor.snapshot() if(uart.any()): time.sleep(200) data = uart.read(8) #uart.readinto(buf,8) #data = uart.readline() #print(buf) if( len(data) >= 8): if((data[0] == 0x55)&(data[1] == 0x02)&(data[7] == 0xBB)): if(data[2] == 0x92): print("识别二维码") if(data[3] == 0x01): #启动识别 if(FlagOK == 0): FlagOK = 1 num = 9 print("开始识别") tim.callback(tick) else: print("正在识别") for rdata in runData: print(rdata) uart.writechar(rdata) if(data[3] == 0x02): print("停止识别") FlagOK = 2 tim.deinit() #定时器停止 Color_Check(data) lcd.display(img)
通过USB-TTL发送串口55 02 92 01 00 00 93 BB识别命令,但发一次或者两次过后,OPENMV进行卡屏,只能拔电重启?
直接read(8), 有可能会粘包,就会等待1s到2s。但是我不清楚是不是主要原因。
而且在最好在主循环里先判断串口,然后再
获取图像。
