  • 代码识别一次或者两次过后,openmv进行卡屏,只能拔电重启摄像头,请问这是怎么回事?
    • import sensor, image,time,lcd
      from pyb import UART,Timer,LED
      sensor.set_framesize(sensor.QVGA)#320*240
      sensor.skip_frames(30)
      sensor.set_auto_whitebal(False)      #关闭白平衡
      sensor.set_auto_gain(False)          #关闭自动增益
      lcd.init()                           #Initialize the lcd screen.
      uart = UART(3,115200,8,None,1)       #创建串口对象
      data = []
      buff=[0,0,0,0,0,0,0,0]
      LED_Red = LED(1)
      LED_Green = LED(2)
      LED_Blue = LED(3)
      tim = Timer(4,freq=1)              # create a timer object using timer 4
      #tim.callback(tick)
      tim.deinit()
      FlagOK = 0
      show_numTab = ["0","1","2","3","4","5","6","7","8","9"]
      num = 0
      returnData = [0x55,0x02,0x92,0x02,0x02,0x00,0x00,0xBB]  #识别失败
      runData    = [0x55,0x02,0x92,0x03,0x02,0x00,0x00,0xBB]  #正在识别
      #定时器回调函数
      def tick(timer):            # we will receive the timer object when being called
          global FlagOK,num,returnData
          print("Timer callback")
          num = num-1
          if(num == 0):
              num = 9
              FlagOK = 2
              tim.deinit()
      #串口发送函数
      def USART_Send(src,length):
          for i in range(length):
              uart.writechar(src[i])
      #   二维码识别,并返回识别结果
      def Color_Check(srcbuf):
          global FlagOK,num
          if(FlagOK == 1):
              img.draw_string(100, 180,"open"+show_numTab[num],color=[255,0,0])
                      FlagOK = 0
                      tim.deinit()
                      print(code)
                      qr_Tab = code.payload()
                      uart.writechar(0x55)
                      uart.writechar(0x02)
                      uart.writechar(0x92)
                      uart.writechar(0x01)
                      uart.writechar(len(qr_Tab))
                      for qrdata in qr_Tab:
                          uart.writechar(ord(qrdata))
                      uart.writechar(0xBB)
          if(FlagOK == 2):
              for rdata in returnData:
                  uart.writechar(rdata)
              FlagOK = 0
          if(uart.any()):
              time.sleep(200)
              data = uart.read(8)
              #uart.readinto(buf,8)
              #data = uart.readline()
              #print(buf)
              if( len(data) >= 8):
                  if((data[0] == 0x55)&(data[1] == 0x02)&(data[7] == 0xBB)):
                      if(data[2] == 0x92):
                          print("识别二维码")
                          if(data[3] == 0x01):    #启动识别
                              if(FlagOK == 0):
                                  FlagOK = 1
                                  num = 9
                                  print("开始识别")
                                  tim.callback(tick)
                                  print("正在识别")
                                  for rdata in runData:
                                      print(rdata)
                          if(data[3] == 0x02):
                              print("停止识别")
                              FlagOK = 2
                              tim.deinit()       #定时器停止
          Color_Check(data)
          lcd.display(img)
      通过USB-TTL发送串口55 02 92 01 00 00 93 BB识别命令,但发一次或者两次过后,OPENMV进行卡屏,只能拔电重启?
    • 直接read(8), 有可能会粘包,就会等待1s到2s。但是我不清楚是不是主要原因。
    • 而且在最好在主循环里先判断串口,然后再img = sensor.snapshot()获取图像。
