关于定时器的使用,设定定时器频率,出现报错
This post is deleted!
请提供全部代码。
请缩减成可以出现报错的最小完整代码。
import sensor, image, pyb, os,time,utime from pyb import Pin, Timer, LED x = 640 y = 180 ROI = (0,300,x,y); sensor.reset() # Initialize the camera sensor. sensor.set_contrast(1) sensor.set_gainceiling(16) sensor.set_pixformat(sensor.GRAYSCALE) sensor.set_framesize(sensor.VGA) sensor.set_windowing(ROI) sensor.skip_frames(time = 1000) # Let new settings take affect. sensor.set_auto_whitebal(False) # Turn off white balance. extra_fb = sensor.alloc_extra_fb(x, y, sensor.GRAYSCALE) extra_fbb = sensor.alloc_extra_fb(x, y, sensor.GRAYSCALE) extra_fb.replace(sensor.snapshot()) extra_fbb.replace(sensor.snapshot()) def CheckingArea(picture): img = sensor.snapshot() img.difference(picture) stats = img.statistics() if (stats[5] > 50): return 1 else: return 0 def systick(timer): # we will receive the timer object when being called print("yes") tim = pyb.Timer(2, freq=10) tim.callback(systick) #循环体 while(True): CheckingArea(extra_fb)
@kidswong999 发现如果有img = sensor.snapshot() 这句代码,就会出现定时器报错
import sensor, image, time from pyb import Pin, Timer sensor.reset() # Reset and initialize the sensor. sensor.set_pixformat(sensor.RGB565) # Set pixel format to RGB565 (or GRAYSCALE) sensor.set_framesize(sensor.QVGA) # Set frame size to QVGA (320x240) sensor.skip_frames(time = 2000) # Wait for settings take effect. clock = time.clock() # Create a clock object to track the FPS. def systick(timer): # we will receive the timer object when being called print("yes") tim = Timer(2, freq=10) tim.callback(systick) while(True): clock.tick() # Update the FPS clock. img = sensor.snapshot() # Take a picture and return the image. print(clock.fps()) # Note: OpenMV Cam runs about half as fast when connected # to the IDE. The FPS should increase once disconnected.
@kidswong999 这个问题无法解决吗?
