搞不懂的语法错误
#main.py # Untitled - By: Lee - 周六 1月 26 2019 # 收开始命令 扫码 找色块 测距 发距离 import sensor, image, time from pyb import UART import json from sending import recive_data() from sending import sending_data() from Sao_Ma import Measure sensor.reset() sensor.set_pixformat(sensor.RGB565) sensor.set_framesize(sensor.QQVGA) sensor.skip_frames(time = 2000) clock = time.clock() uart = UART(3, 19200) while True: order = recive_data() if order == 1: #开始执行命令 fan_kui = ma() #扫码 uart.write(fan_kui) #反馈扫码的数字(整数) time.sleep(1000) N = recive_data() if N == 1: L = measure_distance(N) uart.write(L) #返回距离大小 elif N == 2: L = measure_distance(N) uart.write(L) if N == 3: L = measure_distance(N) uart.write(L)
#seending.py import time from pyb import UART uart = UART(3, 115200) uart.init(115200, bits=8, parity=None, stop=1) # init with given parameters def sending_data(jj): global uart j = jj uart.write('j') #反馈字符串 def recive_data(): global uart tmp_data = 1 if uart.any(): tmp_data = uart.readline() uart.write("RECIVED : %s\n"%tmp_data) print(tmp_data) return tmp_data #while(True): # sending_data(1) # recive_data() # time.sleep(1000)
from import 不需要加括号()
@kidswong999 谢谢小智智
