  • 使用串口发送TypeError: object with buffer protocol required
                    (0, 15, 0, 40, -80, -20)] # generic_blue_thresholds
      uart = UART(3, 9600)
              uart.write(code.payload())
          for blob in img.find_blobs(thresholds, pixels_threshold=200, area_threshold=200):
                  uart.write(blob[8])
    • 求大佬解答下,哭了
    • 数据需要是字符串。
      来自星瞳实验室APP: OpenMV串口发送数据 https://singtown.com/learn/50235/
    • @kidswong999 哦哦哦这样啊,谢谢大佬
