关于缩进
之前编号的程序,一段时间之后加了几句话,就编译不通过了,提示缩进错误,求解决方案
缩进错了,按照逻辑调整一下缩进
也只能这样呀
@kidswong999
真的有问题么?查了很多次了
你把,代码用格式复制一下
import sensor, image, time, math,pyb from pyb import Servo from pyb import UART from pid import PID from pyb import millis from pyb import Pin, Timer sensor.reset() sensor.set_pixformat(sensor.RGB565) sensor.set_framesize(sensor.QQVGA) sensor.skip_frames(time = 2000) sensor.set_auto_gain(False) sensor.set_auto_whitebal(False) f_x = (12 / 3.984) * 160 f_y = (12 / 2.952) * 120 c_x = 160 * 0.5 c_y = 120 * 0.5 s1 = Servo(1) s1.angle(0) x_pid = PID(p=3, i=0.05, imax=50) x1_pid = PID(p=3, i=0.02, imax=50) uart = UART(1, 115200) uart.init(115200, bits=8, parity=None, stop=1) flag=3 flag1=1 flag2=0 c1=-38 f=0 f0=0 def tick(timer): from pyb import Servo global flag global s1 print("Timer callback") s1.angle(0) flag=3 tim = Timer(5, freq=0.1) tim.callback(tick) def tick1(timer): global flag global f global f0 global z0 print("Timer1 callback") if flag==3 and f==0: if f0==0: flag=4 uart.writechar(66) else: if z0>-20: uart.writechar(83) else: uart.writechar(67) flag=4 tim1 = Timer(3, freq=0.3) tim1.callback(tick1) while(True): while(flag!=2): res=uart.readchar() if res>=85 and res<=125: res=res-105 out=x1_pid.get_pid(res,1)+105; if out>125: out=125 if out<85: out=85 uart.writechar(int(out)) if res==67: flag=3 if res==66: flag=4 while(flag==3): img = sensor.snapshot() for tag in img.find_apriltags(families=image.TAG16H5,fx=f_x, fy=f_y, cx=c_x, cy=c_y): f=1 if flag1==0 : uart.writechar(65) flag1=1 else: img.draw_rectangle(tag.rect(), color = (255, 0, 0)) print_args = (tag.x_translation(), tag.z_translation()) print("Tx: %f, ,Tz %f" % print_args) x_output=x_pid.get_pid(tag.x_translation(),1) x_output=x_output*1.2+105 if tag.z_translation()<-15: uart.writechar(int(x_output)) print("out!! %f" % x_output) z0=tag.z_translation() else: uart.writechar(83) flag=2 flag3=0 print("浇水2" ) f0=f f=0 while (flag==4): print("执行了一次4" ) uart.writechar(66) for i in range(90): print("i= %d" %i ) s1.pulse_width(1500 - i*10) img = sensor.snapshot() for tag in img.find_apriltags(families=image.TAG16H5,fx=f_x, fy=f_y, cx=c_x, cy=c_y): print_args = (tag.x_translation(), tag.z_translation()) if tag.x_translation()<3 and tag.x_translation()>-3 : c=int(i/10) c1=-10 out=c+105 uart.writechar(int(out)) flag=3 pyb.delay(300) s1.angle(0) if flag==3: break if flag==4: for i in range(180): print("i= %d" %i ) s1.pulse_width(600 + i*10) img = sensor.snapshot() for tag in img.find_apriltags(families=image.TAG16H5,fx=f_x, fy=f_y, cx=c_x, cy=c_y): print_args = (tag.x_translation(), tag.z_translation()) if tag.x_translation()<3 and tag.x_translation()>-3 : c=int(-(i-90)/10) if c>0: c1=10 else: c1=-10 out=c+105 uart.writechar(out) flag=3 pyb.delay(300) s1.angle(0) if flag==3: break if flag==4: for i in range(90): print("i= %d" %i ) s1.pulse_width(2400 - i*10) img = sensor.snapshot() for tag in img.find_apriltags(families=image.TAG16H5,fx=f_x, fy=f_y, cx=c_x, cy=c_y): print_args = (tag.x_translation(), tag.z_translation()) if tag.x_translation()<3 and tag.x_translation()>-3 : c=int(-(90-i)/10) out=c+105 uart.writechar(out) flag=3 c1=10 pyb.delay(300) s1.angle(0) if flag==3: break if flag==4: uart.writechar(67) pyb.delay(2000)
为什么在IDE里编辑的格式和粘贴在这里的不同呢
我帮你把缩进对齐了,并且OpenMV u盘中保存了pid.py文件,运行后没有问题了。
就是两个问题,你自己检查校对一下。
1.要把pid.py放进openmv的u盘。
2.缩进要对齐。(主要是你代码里if flag==4: 这里)import sensor, image, time, math,pyb from pyb import Servo from pyb import UART from pid import PID from pyb import millis from pyb import Pin, Timer sensor.reset() sensor.set_pixformat(sensor.RGB565) sensor.set_framesize(sensor.QQVGA) sensor.skip_frames(time = 2000) sensor.set_auto_gain(False) sensor.set_auto_whitebal(False) f_x = (12 / 3.984) * 160 f_y = (12 / 2.952) * 120 c_x = 160 * 0.5 c_y = 120 * 0.5 s1 = Servo(1) s1.angle(0) x_pid = PID(p=3, i=0.05, imax=50) x1_pid = PID(p=3, i=0.02, imax=50) uart = UART(1, 115200) uart.init(115200, bits=8, parity=None, stop=1) flag=3 flag1=1 flag2=0 c1=-38 f=0 f0=0 def tick(timer): from pyb import Servo global flag global s1 print("Timer callback") s1.angle(0) flag=3 tim = Timer(5, freq=0.1) tim.callback(tick) def tick1(timer): global flag global f global f0 global z0 print("Timer1 callback") if flag==3 and f==0: if f0==0: flag=4 uart.writechar(66) else: if z0>-20: uart.writechar(83) else: uart.writechar(67) flag=4 tim1 = Timer(3, freq=0.3) tim1.callback(tick1) while(True): while(flag!=2): res=uart.readchar() if res>=85 and res<=125: res=res-105 out=x1_pid.get_pid(res,1)+105; if out>125: out=125 if out<85: out=85 uart.writechar(int(out)) if res==67: flag=3 if res==66: flag=4 while(flag==3): img = sensor.snapshot() for tag in img.find_apriltags(families=image.TAG16H5,fx=f_x, fy=f_y, cx=c_x, cy=c_y): f=1 if flag1==0 : uart.writechar(65) flag1=1 else: img.draw_rectangle(tag.rect(), color = (255, 0, 0)) print_args = (tag.x_translation(), tag.z_translation()) print("Tx: %f, ,Tz %f" % print_args) x_output=x_pid.get_pid(tag.x_translation(),1) x_output=x_output*1.2+105 if tag.z_translation()<-15: uart.writechar(int(x_output)) print("out!! %f" % x_output) z0=tag.z_translation() else: uart.writechar(83) flag=2 flag3=0 print("浇水2" ) f0=f f=0 while (flag==4): print("执行了一次4" ) uart.writechar(66) for i in range(90): print("i= %d" %i ) s1.pulse_width(1500 - i*10) img = sensor.snapshot() for tag in img.find_apriltags(families=image.TAG16H5,fx=f_x, fy=f_y, cx=c_x, cy=c_y): print_args = (tag.x_translation(), tag.z_translation()) if tag.x_translation()<3 and tag.x_translation()>-3 : c=int(i/10) c1=-10 out=c+105 uart.writechar(int(out)) flag=3 pyb.delay(300) s1.angle(0) if flag==3: break if flag==4: for i in range(180): print("i= %d" %i ) s1.pulse_width(600 + i*10) img = sensor.snapshot() for tag in img.find_apriltags(families=image.TAG16H5,fx=f_x, fy=f_y, cx=c_x, cy=c_y): print_args = (tag.x_translation(), tag.z_translation()) if tag.x_translation()<3 and tag.x_translation()>-3 : c=int(-(i-90)/10) if c>0: c1=10 else: c1=-10 out=c+105 uart.writechar(out) flag=3 pyb.delay(300) s1.angle(0) if flag==3: break if flag==4: for i in range(90): print("i= %d" %i ) s1.pulse_width(2400 - i*10) img = sensor.snapshot() for tag in img.find_apriltags(families=image.TAG16H5,fx=f_x, fy=f_y, cx=c_x, cy=c_y): print_args = (tag.x_translation(), tag.z_translation()) if tag.x_translation()<3 and tag.x_translation()>-3 : c=int(-(90-i)/10) out=c+105 uart.writechar(out) flag=3 c1=10 pyb.delay(300) s1.angle(0) if flag==3: break if flag==4: uart.writechar(67) pyb.delay(2000)
