星瞳实验室APP,快速收到回复
  • 使用函数img.histogram.get_threhsold()错误
      想实现自适应阈值对图像进行阈值分割,使用img.histogram.get_threhsold()函数得到阈值时出现错误提示: AttributeError:'bound_method' object has no attribute 'get_threshold',不知道是不是自己函数写错了,不知道有没有人可以帮忙解惑一下
          img = sensor.snapshot().lens_corr(1.0)
      #   image.get_histogram()
          th = img.histogram.get_threhsold([roi])
      #   th = (42, 100, -128, 127, -128, 127)
          img.binary([th],invert = True)
    • 请提供全部的代码
    • # Find Rects Example
      # This example shows off how to find rectangles in the image using the quad threshold
      # detection code from our April Tags code. The quad threshold detection algorithm
      # detects rectangles in an extremely robust way and is much better than Hough
      # Transform based methods. For example, it can still detect rectangles even when lens
      # distortion causes those rectangles to look bent. Rounded rectangles are no problem!
      # (But, given this the code will also detect small radius circles too)...
      import sensor, image, time, lcd
      sensor.set_pixformat(sensor.RGB565) # grayscale is faster (160x120 max on OpenMV-M7)
      lcd.init()
      roi = (80,0,80,120)#搜索矩形的图像区域
      #kernel_size = 1 # kernel width = (size*2)+1, kernel height = (size*2)+1
      #kernel = [-1, -1, -1,\
      #         -1, +9, -1,\
      #         -1, -1, -1]
      #   th = img.histogram.get_threhsold([roi])
      #   img.binary([th],invert = True)
      #   img.find_edges(image.EDGE_CANNY, threshold=(50, 80))
      #   img.laplacian(2)
          # `threshold` below should be set to a high enough value to filter out noise
          # rectangles detected in the image which have low edge magnitudes. Rectangles
          # have larger edge magnitudes the larger and more contrasty they are...
          for r in img.find_rects(roi,threshold = 10000):
              statistics = img.get_statistics(roi=r.rect())
              print(statistics)
              if statistics.mean() <= 50:
              lcd.display(img)
              print(r.rect())
          print("FPS %f" % clock.fps())
    • @kidswong999
      lcd.init()
      #         -1, +9, -1,\
      #         -1, -1, -1]
      #   img.laplacian(2)
              print(statistics)
              lcd.display(img)
              print(r.rect())
    • img = sensor.snapshot().lens_corr(1.0)
      hist = img.get_histogram()
      th = hist.get_threshold()
