有是这个问题MemoryError
所有关于机器学习的案例都报这个错误
MemoryError:Out of normal MicroPython Heap Memory!Please reduce the resolution of the image you are running this algorithm on to bypass this issue!
我买的是假的吧
请提供报错的代码。
@yuan 所有都是,随便来个第一个
# cifar10例程 import sensor, image, time, os, nn sensor.reset() # Reset and initialize the sensor. sensor.set_contrast(3) sensor.set_pixformat(sensor.RGB565) # Set pixel format to RGB565 sensor.set_framesize(sensor.QVGA) # Set frame size to QVGA (320x240) sensor.set_windowing((128, 128)) # Set 128x128 window. sensor.skip_frames(time=1000) sensor.set_auto_gain(False) sensor.set_auto_exposure(False) # 加载cifar10网络。OpenMV3 M7上使用此网络可能会超出内存。 #net = nn.load('/cifar10.network') # 更快,更小,更准确。建议OpenMV3 M7上使用此网络。 net = nn.load('/cifar10_fast.network') labels = ['airplane', 'automobile', 'bird', 'cat', 'deer', 'dog', 'frog', 'horse', 'ship', 'truck'] clock = time.clock() # Create a clock object to track the FPS. while(True): clock.tick() # Update the FPS clock. img = sensor.snapshot() # Take a picture and return the image. out = net.forward(img) max_idx = out.index(max(out)) score = int(out[max_idx]*100) if (score < 70): score_str = "??:??%" else: score_str = "%s:%d%% "%(labels[max_idx], score) img.draw_string(0, 0, score_str, color=(255, 0, 0)) print(clock.fps()) # Note: OpenMV Cam runs about half as fast when connected # to the IDE. The FPS should increase once disconnected. ```上次你就没解决 大佬
你有运行过这个代码吗?
请截一下这个代码报错的图。
请运行这个代码报错截图,请把代码一起截上。
请按照教程操作,请运行教程里面的代码。你的代码和教程的不一样。
