  • open MV与STM32控制板连接进行UART串口通讯,但是IDE中运行报错没有pyb模块是什么原因?
    • # OpenMV Object Tracking with UART Communication to STM32 (保持目标检测显示不变)
      # Copyright (c) 2013-2024 OpenMV LLC. All rights reserved.
      import sensor, image, time, ml, math, uos, gc
      import pyb
      # 初始化摄像头
      sensor.skip_frames(time=2000)
      # 初始化UART (波特率115200)
      # 目标区域设置
      TARGET_CENTER_X = 120  # 图像中心X坐标
      TARGET_WIDTH = 20      # 目标区域宽度
      MAX_SERVO_ANGLE = 45   # 最大舵机角度
      # 数据包格式定义
      HEADER = 0xAA  # 数据包头
      FOOTER = 0x55  # 数据包尾
      # 加载模型和标签 (保持不变)
      net = None
      labels = None
      min_confidence = 0.5
          net = ml.Model("trained.tflite", load_to_fb=uos.stat('trained.tflite')[6] > (gc.mem_free() - (64*1024)))
      except Exception as e:
          raise Exception('Failed to load model: ' + str(e))
          raise Exception('Failed to load labels: ' + str(e))
      # 颜色定义
      colors = [
          (255, 0, 0), (0, 255, 0), (255, 255, 0),
          (0, 0, 255), (255, 0, 255), (0, 255, 255), (255, 255, 255)
      # 后处理函数
          ob, oh, ow, oc = model.output_shape[0]
          x_scale = inputs[0].roi[2] / ow
          y_scale = inputs[0].roi[3] / oh
          scale = min(x_scale, y_scale)
          l = [[] for i in range(oc)]
          for i in range(oc):
              blobs = img.find_blobs(threshold_list, x_stride=1, y_stride=1, area_threshold=1, pixels_threshold=1)
              for b in blobs:
                  rect = b.rect()
                  x, y, w, h = rect
                  score = img.get_statistics(thresholds=threshold_list, roi=rect).l_mean() / 255.0
                  x = int((x * scale) + x_offset)
                  w = int(w * scale)
                  h = int(h * scale)
          return l
      def send_angle_to_stm32(angle):
          """发送角度数据给STM32 (二进制协议)"""
          angle_int = int(angle * 100)  # 转换为0.01度单位
          data = bytearray([
              HEADER,
              (angle_int >> 8) & 0xFF,  # 角度高字节
              angle_int & 0xFF,         # 角度低字节
              FOOTER
          uart.write(data)
          # print("Sent:AA %02X %02X 55 (Angle=%.2f°)" % (data[1],data[2],angle))
      def calculate_servo_angle(target_x):
          """计算舵机角度"""
          angle = (target_x - TARGET_CENTER_X) * (MAX_SERVO_ANGLE / TARGET_CENTER_X)
          angle = max(-MAX_SERVO_ANGLE, min(MAX_SERVO_ANGLE, angle))
          print("Servo angle requireed:{:.2f}".format(angle))
          return angle
          # 绘制目标区域
          img.draw_rectangle((TARGET_CENTER_X-TARGET_WIDTH//2, 0, TARGET_WIDTH, img.height()), color=(0, 255, 0))
          detected_objects = []
          # 目标检测逻辑
              if i == 0 or len(detection_list) == 0:
                  continue
              print(f"----- {labels[i]} -----")
              for x, y, w, h, score in detection_list:
                  center_x = math.floor(x + w/2)
                  center_y = math.floor(y + h/2)
                  detected_objects.append((center_x, center_y, score))
                  # 绘制逻辑
                  img.draw_string(x, y-10, f"{score:.2f°}", color=colors[i])
          # 如果有检测到目标,计算平均位置
          if detected_objects:
              # 加权平均计算
              total_weight = sum(score for _, _, score in detected_objects)
              avg_x = sum(x*score for x, _, score in detected_objects) / total_weight
              # 计算角度并打印
              angle = calculate_servo_angle(avg_x)
              # 计算角度并发送给STM32
          #    # 模拟目标位置(中心右侧30像素)
          # test_x = TARGET_CENTER_X + 30
          # test_angle = (test_x - TARGET_CENTER_X) * (MAX_SERVO_ANGLE / TARGET_CENTER_X)
          #    # 发送虚拟数据
          # send_angle_to_stm32(test_angle)
          #    # 保持可视化(可选)
          # img.draw_cross(int(test_x), 120, color=(255,0,0), size=20)
          # img.draw_string(10, 10, "调试模式: Angle=%.1f°" % test_angle)
          # time.sleep_ms(100)  # 控制输出频率
              img.draw_cross(int(avg_x), color=(255, 0, 0), size=20)
              img.draw_string(10, 10, f"Target: {int(avg_x)}", color=(255, 255, 255))
              img.draw_string(10, 25, f"Angle: {angle:.1f}°", color=(255, 255, 255))
              print(f"FPS: {clock.fps():.1f}\n")
      ![0_1747124658069_屏幕截图 2025-05-13 162350.png](https://fcdn.singtown.com/1d01489f-920b-4c28-9faf-d6a8e708d49c.png)
