这个w,h为什么是定值?
Edge Impulse - OpenMV FOMO Object Detection Example
This work is licensed under the MIT license.
Copyright (c) 2013-2024 OpenMV LLC. All rights reserved.
https://github.com/openmv/openmv/blob/master/LICENSE
import sensor, image, time, os, ml, math, uos, gc
from ulab import numpy as npsensor.reset() # Reset and initialize the sensor.
sensor.skip_frames(time=2000) # Let the camera adjust.net = None
labels = None
min_confidence = 0.5try:
net = ml.Model("trained.tflite", load_to_fb=uos.stat('trained.tflite')[6] > (gc.mem_free() - (64*1024)))
except Exception as e:
raise Exception('Failed to load "trained.tflite", did you copy the .tflite and labels.txt file onto the mass-storage device? (' + str(e) + ')')try:
raise Exception('Failed to load "labels.txt", did you copy the .tflite and labels.txt file onto the mass-storage device? (' + str(e) + ')')colors = [ # Add more colors if you are detecting more than 7 types of classes at once.
(255, 0, 0),
( 0, 255, 0),
(255, 255, 0),
( 0, 0, 255),
(255, 0, 255),
( 0, 255, 255),
(255, 255, 255),
]threshold_list = [(math.ceil(min_confidence * 255), 255)]
ob, oh, ow, oc = model.output_shape[0]x_scale = inputs[0].roi[2] / ow y_scale = inputs[0].roi[3] / oh scale = min(x_scale, y_scale) x_offset = ((inputs[0].roi[2] - (ow * scale)) / 2) + inputs[0].roi[0] y_offset = ((inputs[0].roi[3] - (ow * scale)) / 2) + inputs[0].roi[1] l = [[] for i in range(oc)] for i in range(oc): img = image.Image(outputs[0][0, :, :, i] * 255) blobs = img.find_blobs( threshold_list, x_stride=1, y_stride=1, area_threshold=1, pixels_threshold=1 ) for b in blobs: rect = b.rect() x, y, w, h= rect score = ( img.get_statistics(thresholds=threshold_list, roi=rect).l_mean() / 255.0 ) x = int((x * scale) + x_offset) y = int((y * scale) + y_offset) w = int(w * scale) h = int(h * scale) l[i].append((x, y, w, h, score)) return l
clock.tick()img = sensor.snapshot() for i, detection_list in enumerate(net.predict([img], callback=fomo_post_process)): if i == 0: continue # background class if len(detection_list) == 0: continue # no detections for this class? print("********** %s **********" % labels[i]) for x, y, w, h, score in detection_list: center_x = math.floor(x + (w / 2)) center_y = math.floor(y + (h / 2)) print(f"x {center_x}\ty {center_y}\tscore {score}\tw{w}\th{h}") img.draw_circle((center_x, center_y, 12), color=colors[i]) print(clock.fps(), "fps", end="\n\n")
FOMO是关键点检测,无法获得宽度和高度。
