  • 这个w,h为什么是定值?
    • Edge Impulse - OpenMV FOMO Object Detection Example
      This work is licensed under the MIT license.
      Copyright (c) 2013-2024 OpenMV LLC. All rights reserved.
      https://github.com/openmv/openmv/blob/master/LICENSE
      import sensor, image, time, os, ml, math, uos, gc
      from ulab import numpy as np
      net = None
      labels = None
      min_confidence = 0.5
      net = ml.Model("trained.tflite", load_to_fb=uos.stat('trained.tflite')[6] > (gc.mem_free() - (64*1024)))
      except Exception as e:
      (255, 0, 0),
      ( 0, 255, 0),
      (255, 255, 0),
      ( 0, 0, 255),
      (255, 0, 255),
      ( 0, 255, 255),
      (255, 255, 255),
      threshold_list = [(math.ceil(min_confidence * 255), 255)]
      def fomo_post_process(model, inputs, outputs):
      ob, oh, ow, oc = model.output_shape[0]
      x_scale = inputs[0].roi[2] / ow
      y_scale = inputs[0].roi[3] / oh
      scale = min(x_scale, y_scale)
      x_offset = ((inputs[0].roi[2] - (ow * scale)) / 2) + inputs[0].roi[0]
      y_offset = ((inputs[0].roi[3] - (ow * scale)) / 2) + inputs[0].roi[1]
      l = [[] for i in range(oc)]
      for i in range(oc):
          img = image.Image(outputs[0][0, :, :, i] * 255)
          blobs = img.find_blobs(
              threshold_list, x_stride=1, y_stride=1, area_threshold=1, pixels_threshold=1
          for b in blobs:
              rect = b.rect()
              x, y, w, h= rect
              score = (
                  img.get_statistics(thresholds=threshold_list, roi=rect).l_mean() / 255.0
              x = int((x * scale) + x_offset)
              y = int((y * scale) + y_offset)
              w = int(w * scale)
              h = int(h * scale)
              l[i].append((x, y, w, h, score))
      return l
      for i, detection_list in enumerate(net.predict([img], callback=fomo_post_process)):
          if i == 0: continue  # background class
          if len(detection_list) == 0: continue  # no detections for this class?
          for x, y, w, h, score in detection_list:
              print(f"x {center_x}\ty {center_y}\tscore {score}\tw{w}\th{h}")
              img.draw_circle((center_x, center_y, 12), color=colors[i])
    • FOMO是关键点检测,无法获得宽度和高度。
