  • 'module' object has no attribute 'load'报错
    • 'module' object has no attribute 'load'报错,或AttributeError: 'module' object has no attribute 'load_builtin_model'报错
      本质上应该是impot了tf模块并使用了tf.load方法,但是不知道为什么提示没有这个方法
      之前运行例程讲解25-FOMO人检测时也出现了类似的问题,只要引用tf模块就会出现这个问题,ide(4.5.0)和固件(4.6.20)是最新版本
      时间紧张,希望尽快答复,十分感谢技术支持人员
      # 人体姿态识别部署代码 (保存为main.py)
      import sensor, image, time, tf, os
      # 硬件初始化
      sensor.set_pixformat(sensor.RGB565)  # 必须使用RGB模式
      sensor.set_framesize(sensor.QVGA)    # 320x240 (根据摄像头调整)
      sensor.skip_frames(time=2000)
      # 模型配置
      MODEL_PATH = "model.tflite"
      INPUT_SIZE = (368, 368)  # 根据模型实际输入尺寸调整
      HEATMAP_THRESHOLD = 0.3  # 关键点置信度阈值
      # 关键点定义(与训练时一致)
      BODY_PARTS = {
          0: "Nose", 1: "Neck", 2: "RShoulder", 3: "RElbow", 4: "RWrist",
          5: "LShoulder", 6: "LElbow", 7: "LWrist", 8: "RHip", 9: "RKnee",
          10: "RAnkle", 11: "LHip", 12: "LKnee", 13: "LAnkle", 14: "REye",
          15: "LEye", 16: "REar", 17: "LEar"
      POSE_PAIRS = [
          ["Neck", "RShoulder"], ["Neck", "LShoulder"],  # 修正原始代码的拼写错误
          ["RShoulder", "RElbow"], ["RElbow", "RWrist"],
          ["LShoulder", "LElbow"], ["LElbow", "LWrist"],
          ["Neck", "RHip"], ["RHip", "RKnee"], ["RKnee", "RAnkle"],
          ["Neck", "LHip"], ["LHip", "LKnee"], ["LKnee", "LAnkle"],
          ["Neck", "Nose"], ["Nose", "REye"], ["REye", "REar"],
          ["Nose", "LEye"], ["LEye", "LEar"]
      # 加载模型
          net = tf.load(MODEL_PATH)
      except Exception as e:
          raise Exception(f"{str(e)}")
      def preprocess(img):
          图像预处理(必须与训练时的处理完全一致)
          原始预处理参数:
          - 尺寸缩放: 368x368
          - 归一化: (像素值 - 127.5) / 127.5
          - 颜色通道: RGB
          # 调整尺寸(保持宽高比的缩放)
          resized = img.resize(INPUT_SIZE[0], INPUT_SIZE[1])
          # 转换为RGB888格式(需要先转换为RGB565再转换回来)
          rgb_img = resized.to_rgb565().to_grayscale(color_copy=True)
          # 分配Tensor内存(根据模型输入形状)
          input_tensor = tf.allocate(INPUT_SIZE + (3,), dtype=tf.float32)
          # 数据归一化
          for y in range(INPUT_SIZE[1]):
              for x in range(INPUT_SIZE[0]):
                  r, g, b = rgb_img.get_pixel(x, y)
                  # 归一化到[-1,1]范围
                  input_tensor[0, y, x, 0] = (r - 127.5) / 127.5
                  input_tensor[0, y, x, 1] = (g - 127.5) / 127.5
                  input_tensor[0, y, x, 2] = (b - 127.5) / 127.5
          return input_tensor
      def postprocess(output_tensor, original_w, original_h):
          解析模型输出
          输出形状应为 [1, num_points, height, width]
          points = []
          # 获取热力图维度
          _, num_points, heat_h, heat_w = output_tensor.shape
          # 遍历所有关键点
          for i in range(num_points):
              heatmap = output_tensor[0][i]
              # 寻找最大值位置
              max_val = 0
              max_x, max_y = 0, 0
              for y in range(heat_h):
                  for x in range(heat_w):
                      val = heatmap[y][x]
                      if val > max_val:
                          max_val = val
                          max_x, max_y = x, y
              # 转换到原图坐标
              if max_val > HEATMAP_THRESHOLD:
                  x = int((max_x / heat_w) * original_w)
                  y = int((max_y / heat_h) * original_h)
                  points.append((x, y))
                  points.append(None)
          return points
      # 主循环
          # 捕获图像
              # 预处理
              tensor = preprocess(img)
              # 执行推理
              start = time.ticks_ms()
              output = net.predict(tensor)
              inference_time = time.ticks_ms() - start
              # 后处理
              points = postprocess(output, img.width(), img.height())
              # 绘制骨架
              for pair in POSE_PAIRS:
                  part_a = BODY_PARTS.get(pair[0], None)
                  part_b = BODY_PARTS.get(pair[1], None)
                  if part_a is not None and part_b is not None:
                      id_a = int(part_a.split("_")[-1]) if isinstance(part_a, str) else part_a
                      id_b = int(part_b.split("_")[-1]) if isinstance(part_b, str) else part_b
                      if points[id_a] and points[id_b]:
                          img.draw_line(points[id_a][0], points[id_a][1],
                                       points[id_b][0], points[id_b][1],
                                       color=(0, 255, 0), thickness=2)
                          # 绘制关节点
                          img.draw_circle(points[id_a][0], points[id_a][1], 3,
                                         color=(255, 0, 0), thickness=2)
                          img.draw_circle(points[id_b][0], points[id_b][1], 3,
              # 显示性能
              fps = clock.fps()
              img.draw_string(10, 10, f"FPS: {fps:.1f}\nInference: {inference_time}ms",
                             color=(255, 0, 0), scale=1.5)
              print("处理出错:", str(e))
          # 显示图像
          img.flush()
      以及例程25:
      # TensorFlow Lite 目标点检测示例
      # 本例程使用内置的FOMO模型检测人脸。
      import sensor
      import tf
      import math
      sensor.reset()  # 重置并初始化感光元件
      sensor.set_pixformat(sensor.RGB565)  # 设置图像格式为 RGB565 (或 GRAYSCALE)
      sensor.set_framesize(sensor.QVGA)  # 设置图像大小为 QVGA (320x240)
      sensor.set_windowing((240, 240))  # 设置图像为 240x240 窗口大小
      sensor.skip_frames(time=2000)  # 跳过几帧使设置生效
      min_confidence = 0.4
      # 加载内置的 FOMO 人脸检测模型
      labels, net = tf.load_builtin_model("fomo_face_detection")
      # 或者,模型文件也可以从文件系统存储中加载。
      # net = tf.load('<object_detection_network>', load_to_fb=True)
      # labels = [line.rstrip('\n') for line in open("labels.txt")]
      colors = [  # 可以添加更多标识圈的颜色,可以超过7种,不同种类目标物体用不同颜色圈表示
          (255, 0, 0),
          (0, 255, 0),
          (255, 255, 0),
          (0, 0, 255),
          (255, 0, 255),
          (0, 255, 255),
          (255, 255, 255),
          # detect() 返回图像中检测到的所有的物体 (已经按照种类分类好)
          # 跳过索引0, 因为第0个分类是 背景
          # 然后在识别到的物体中央画出圆圈
          for i, detection_list in enumerate(
              net.detect(img, thresholds=[(math.ceil(min_confidence * 255), 255)])
              if i == 0:
                  continue  # 索引0是背景分类
              if len(detection_list) == 0:
                  continue  # 没有检测到这个种类的物体
              for d in detection_list:
                  [x, y, w, h] = d.rect()
                  print(f"x {center_x}\ty {center_y}")
          print(clock.fps(), "fps", end="\n")
