'module' object has no attribute 'load'报错
'module' object has no attribute 'load'报错,或AttributeError: 'module' object has no attribute 'load_builtin_model'报错
本质上应该是impot了tf模块并使用了tf.load方法,但是不知道为什么提示没有这个方法
之前运行例程讲解25-FOMO人检测时也出现了类似的问题,只要引用tf模块就会出现这个问题,ide(4.5.0)和固件(4.6.20)是最新版本
时间紧张,希望尽快答复,十分感谢技术支持人员
# 人体姿态识别部署代码 (保存为main.py) import sensor, image, time, tf, os # 硬件初始化 sensor.reset() sensor.set_pixformat(sensor.RGB565) # 必须使用RGB模式 sensor.set_framesize(sensor.QVGA) # 320x240 (根据摄像头调整) sensor.skip_frames(time=2000) clock = time.clock() # 模型配置 MODEL_PATH = "model.tflite" INPUT_SIZE = (368, 368) # 根据模型实际输入尺寸调整 HEATMAP_THRESHOLD = 0.3 # 关键点置信度阈值 # 关键点定义(与训练时一致) BODY_PARTS = { 0: "Nose", 1: "Neck", 2: "RShoulder", 3: "RElbow", 4: "RWrist", 5: "LShoulder", 6: "LElbow", 7: "LWrist", 8: "RHip", 9: "RKnee", 10: "RAnkle", 11: "LHip", 12: "LKnee", 13: "LAnkle", 14: "REye", 15: "LEye", 16: "REar", 17: "LEar" } POSE_PAIRS = [ ["Neck", "RShoulder"], ["Neck", "LShoulder"], # 修正原始代码的拼写错误 ["RShoulder", "RElbow"], ["RElbow", "RWrist"], ["LShoulder", "LElbow"], ["LElbow", "LWrist"], ["Neck", "RHip"], ["RHip", "RKnee"], ["RKnee", "RAnkle"], ["Neck", "LHip"], ["LHip", "LKnee"], ["LKnee", "LAnkle"], ["Neck", "Nose"], ["Nose", "REye"], ["REye", "REar"], ["Nose", "LEye"], ["LEye", "LEar"] ] # 加载模型 try: net = tf.load(MODEL_PATH) except Exception as e: raise Exception(f"{str(e)}") def preprocess(img): """ 图像预处理(必须与训练时的处理完全一致) 原始预处理参数: - 尺寸缩放: 368x368 - 归一化: (像素值 - 127.5) / 127.5 - 颜色通道: RGB """ # 调整尺寸(保持宽高比的缩放) resized = img.resize(INPUT_SIZE[0], INPUT_SIZE[1]) # 转换为RGB888格式(需要先转换为RGB565再转换回来) rgb_img = resized.to_rgb565().to_grayscale(color_copy=True) # 分配Tensor内存(根据模型输入形状) input_tensor = tf.allocate(INPUT_SIZE + (3,), dtype=tf.float32) # 数据归一化 for y in range(INPUT_SIZE[1]): for x in range(INPUT_SIZE[0]): r, g, b = rgb_img.get_pixel(x, y) # 归一化到[-1,1]范围 input_tensor[0, y, x, 0] = (r - 127.5) / 127.5 input_tensor[0, y, x, 1] = (g - 127.5) / 127.5 input_tensor[0, y, x, 2] = (b - 127.5) / 127.5 return input_tensor def postprocess(output_tensor, original_w, original_h): """ 解析模型输出 输出形状应为 [1, num_points, height, width] """ points = [] # 获取热力图维度 _, num_points, heat_h, heat_w = output_tensor.shape # 遍历所有关键点 for i in range(num_points): heatmap = output_tensor[0][i] # 寻找最大值位置 max_val = 0 max_x, max_y = 0, 0 for y in range(heat_h): for x in range(heat_w): val = heatmap[y][x] if val > max_val: max_val = val max_x, max_y = x, y # 转换到原图坐标 if max_val > HEATMAP_THRESHOLD: x = int((max_x / heat_w) * original_w) y = int((max_y / heat_h) * original_h) points.append((x, y)) else: points.append(None) return points # 主循环 while True: clock.tick() # 捕获图像 img = sensor.snapshot() try: # 预处理 tensor = preprocess(img) # 执行推理 start = time.ticks_ms() output = net.predict(tensor) inference_time = time.ticks_ms() - start # 后处理 points = postprocess(output, img.width(), img.height()) # 绘制骨架 for pair in POSE_PAIRS: part_a = BODY_PARTS.get(pair[0], None) part_b = BODY_PARTS.get(pair[1], None) if part_a is not None and part_b is not None: id_a = int(part_a.split("_")[-1]) if isinstance(part_a, str) else part_a id_b = int(part_b.split("_")[-1]) if isinstance(part_b, str) else part_b if points[id_a] and points[id_b]: img.draw_line(points[id_a][0], points[id_a][1], points[id_b][0], points[id_b][1], color=(0, 255, 0), thickness=2) # 绘制关节点 img.draw_circle(points[id_a][0], points[id_a][1], 3, color=(255, 0, 0), thickness=2) img.draw_circle(points[id_b][0], points[id_b][1], 3, color=(255, 0, 0), thickness=2) # 显示性能 fps = clock.fps() img.draw_string(10, 10, f"FPS: {fps:.1f}\nInference: {inference_time}ms", color=(255, 0, 0), scale=1.5) except Exception as e: print("处理出错:", str(e)) # 显示图像 img.flush()
以及例程25:
# TensorFlow Lite 目标点检测示例 # # 本例程使用内置的FOMO模型检测人脸。 import sensor import time import tf import math sensor.reset() # 重置并初始化感光元件 sensor.set_pixformat(sensor.RGB565) # 设置图像格式为 RGB565 (或 GRAYSCALE) sensor.set_framesize(sensor.QVGA) # 设置图像大小为 QVGA (320x240) sensor.set_windowing((240, 240)) # 设置图像为 240x240 窗口大小 sensor.skip_frames(time=2000) # 跳过几帧使设置生效 min_confidence = 0.4 # 加载内置的 FOMO 人脸检测模型 labels, net = tf.load_builtin_model("fomo_face_detection") # 或者,模型文件也可以从文件系统存储中加载。 # net = tf.load('<object_detection_network>', load_to_fb=True) # labels = [line.rstrip('\n') for line in open("labels.txt")] colors = [ # 可以添加更多标识圈的颜色,可以超过7种,不同种类目标物体用不同颜色圈表示 (255, 0, 0), (0, 255, 0), (255, 255, 0), (0, 0, 255), (255, 0, 255), (0, 255, 255), (255, 255, 255), ] clock = time.clock() while True: clock.tick() img = sensor.snapshot() # detect() 返回图像中检测到的所有的物体 (已经按照种类分类好) # 跳过索引0, 因为第0个分类是 背景 # 然后在识别到的物体中央画出圆圈 for i, detection_list in enumerate( net.detect(img, thresholds=[(math.ceil(min_confidence * 255), 255)]) ): if i == 0: continue # 索引0是背景分类 if len(detection_list) == 0: continue # 没有检测到这个种类的物体 print("********** %s **********" % labels[i]) for d in detection_list: [x, y, w, h] = d.rect() center_x = math.floor(x + (w / 2)) center_y = math.floor(y + (h / 2)) print(f"x {center_x}\ty {center_y}") img.draw_circle((center_x, center_y, 12), color=colors[i], thickness=2) print(clock.fps(), "fps", end="\n")
重新在edge impulse上下载模型和代码。
