  • 最后blobs出问题了,怎么把tuple弄成int
    • # Edge Impulse - OpenMV FOMO Object Detection Example
      # Copyright (c) 2013-2024 OpenMV LLC. All rights reserved.
      import sensor, image, time, os, ml, math, uos, gc
      from ulab import numpy as np
      net = None
      labels = None
      min_confidence = 0.5
          net = ml.Model("trained.tflite", load_to_fb=uos.stat('trained.tflite')[6] > (gc.mem_free() - (64*1024)))
      except Exception as e:
          (255,   0,   0),
          (  0, 255,   0),
          (255, 255,   0),
          (  0,   0, 255),
          (255,   0, 255),
          (  0, 255, 255),
          (255, 255, 255),
          ob, oh, ow, oc = model.output_shape[0]
          x_scale = inputs[0].roi[2] / ow
          y_scale = inputs[0].roi[3] / oh
          scale = min(x_scale, y_scale)
          l = [[] for i in range(oc)]
          for i in range(oc):
              blobs = img.find_blobs(
                  threshold_list, x_stride=1, y_stride=1, area_threshold=1, pixels_threshold=1
              for b in blobs:
                  rect = b.rect()
                  x, y, w, h = rect
                  score = (
                  x = int((x * scale) + x_offset)
                  w = int(w * scale)
                  h = int(h * scale)
          return l
      sensor.set_auto_gain(False) # 颜色跟踪必须关闭自动增益
      sensor.set_auto_whitebal(False) # 颜色跟踪必须关闭白平衡
      thresholds = [(20, 30, 100, 127, 100, 127)]  # 绿色阈值范围[1,3](@ref)```
      roi = (15, 15, 30, 30)  # 需根据实际场景调整[3](@ref)```
              if i == 0: continue  # background class
              if len(detection_list) == 0: continue  # no detections for this class?
              for x, y, w, h, score in detection_list:
                  print(f"x {center_x}\ty {center_y}\tscore {score}")
          img.histeq(adaptive=True)
          blobs = img.find_blobs([thresholds], roi=roi, invert=False)
              total_green_pixels = sum(blob.pixels() for blob in blobs)  # 累加所有绿色色块的像素数[3](@ref)```
          print(total_green_pixels/900)
      请在这里粘贴代码
    • blobs = img.find_blobs([thresholds], roi=roi, invert=False)
      改为
      blobs = img.find_blobs(thresholds, roi=roi, invert=False)
