  • 出现TypeError: extra positional arguments given问题,怎么解决?
    • 代码如下:
      import sensor, time, display
      import image
      # 摄像头初始化
      sensor.set_vflip(0)  # 摄像头后置模式
      # LCD初始化
      lcd = display.SPIDisplay()
      # 获取中心区域的坐标和尺寸
      def get_center_grid_coords():
          screen_width = lcd.width()
          screen_height = lcd.height()
          step = 200  # 设定为200x200的区域
          x = (screen_width - step) // 2
          y = (screen_height - step) // 2
          return (x, y, step, step)
      # 获取9个小方格区域的坐标和尺寸
      def get_subgrid_coords(x, y, w, h):
          subgrid_size = w // 3  # 每个小方格的尺寸
          subgrid_coords = []
          for j in range(3):
              for i in range(3):
                  sub_x = x + i * subgrid_size
                  sub_y = y + j * subgrid_size
                  subgrid_coords.append((sub_x, sub_y, subgrid_size, subgrid_size))
          return subgrid_coords
      # 计算灰度值
      def get_gray_value(image, x, y):
          return image.get_pixel(x, y)  # 获取灰度值
      # 计算每个小方格中心的颜色
      def classify_subgrids(img, subgrid_coords):
          result = [[0] * 3 for _ in range(3)]
          # 转换为灰度图像
          gray_img = img.to_grayscale()
          for i, (x, y, w, h) in enumerate(subgrid_coords):
              subgrid_img = gray_img.copy().crop((x, y, w, h))
              # 计算小方格中心点的坐标
              center_x = w // 2
              center_y = h // 2
              # 获取中心点的灰度值
              center_gray_value = get_gray_value(subgrid_img, center_x, center_y)
              # 判断灰度值
              if center_gray_value < 50:  # 判断是否为黑子
                  result[i // 3][i % 3] = 1  # 黑子
                  img.draw_rectangle(x, y, w, h, color=(255, 255, 255))  # 白色矩形标记
                  img.draw_string(x + 10, y + 10, 'Black', color=(255, 255, 255))  # 白色文字
              elif center_gray_value > 200:  # 判断是否为白子
                  result[i // 3][i % 3] = 0  # 白子
                  img.draw_rectangle(x, y, w, h, color=(0, 0, 0))  # 黑色矩形标记
                  img.draw_string(x + 10, y + 10, 'White', color=(0, 0, 0))  # 黑色文字
                  result[i // 3][i % 3] = 3  # 无子
                  img.draw_string(x + 10, y + 10, 'None', color=(0, 0, 0))  # 黑色文字
          return result
      # 主循环
          # 获取中心区域的坐标和尺寸
          center_grid_coords = get_center_grid_coords()
          # 获取9个小方格的坐标
          subgrid_coords = get_subgrid_coords(*center_grid_coords)
          # 识别颜色并分类棋子
          grid_result = classify_subgrids(img, subgrid_coords)
          # 打印棋盘状态
          for row in grid_result:
              print(row)
          # LCD显示图片
          lcd.write(img)
          # 打印FPS
      其中,在
      报错
    • subgrid_img = gray_img.copy().crop((x, y, w, h))
      改为
      subgrid_img = gray_img.copy().crop(roi=(x, y, w, h))
