  • memory allocation failed, allocating 153600 bytes
    • 我加载多个模板就会报错,这个要怎么解决,
      0_1721638478864_7480df6c-121a-4790-bca3-f9faa1493459-0cc65d493531258d0072468a98b7e2df.png
      #导入函数库1
      #import lcd
      #开启时钟
      clock = time.clock()# 跟踪FPS帧率
      uart = UART(3, 19200)
      #变量初始化
      #阈值设置 根据实际情况进行更改
      TRA_TH= [(160, 255)]           #巡线的灰度值 阈值[(0, 64)][(128, 255)]
      TRA_AngTH=25                   #巡线时角度阈值
      #ROI区域设置
      #(x,y,w,h,weight)=(矩形左上顶点的坐标(x,y),矩形宽度和高度(w,h),权重)
      TRA_ROIS = [ # [ROI, weight]
              (40, 200, 240, 60, 0.7), # You'll need to tweak the weights for your app
              (40, 100, 240, 60, 0.3), # depending on how your robot is setup.
              (40,   0, 240, 60, 0.1)
      Weight_Sum = 0                        #权值和初始化
      for r in TRA_ROIS: Weight_Sum += r[4] #计算权值和
      #OBS_ROI = [(30 , 10, 100, 100)] #避障模式ROI区域
      #通信数据包封装
      Run     = bytearray([0xB5,
      0x05, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0xDA])# $OMV1&#  直行
      Left    = bytearray([0xB5,
      0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0xDA])# $OMV2&#  左转
      LLeft    = bytearray([0xB5,
      0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0xDA])# $OMV2&#  左转
      Right   = bytearray([0xB5,
      0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0xDA])# $OMV3&#  右转
      RRight   = bytearray([0xB5,
      0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0xDA])# $OMV3&#  右转
      Stop    = bytearray([0xB5,
      0xDA])# $OMV4&#  停止
      Turn_Right    = bytearray([0xB5,
      0x06, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0xDA])
      Turn_Left    = bytearray([0xB5,
      0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      0xDA])
      #Fun1:获得最大色块的位置索引函数
      #输入:N个色块(blobs) 输出:N个色块中最大色块的索引(int i)
      def Get_MaxIndex(blobs):
          maxb_index=0                      #最大色块索引初始化
          max_pixels=0                      #最大像素值初始化
          for i in range(len(blobs)):       #对N个色块进行N次遍历
              if blobs[i].pixels() > max_pixels:#当某个色块像素大于最大值
                  max_pixels = blobs[i].pixels()#更新最大像素
                  maxb_index = i                #更新最大索引
                  return  maxb_index
      def Recive_data():
          global OVSys_State
          if uart.any():                  #如果串口接收到数据
              OVSys_State=int(uart.read())  #将读到的数据强制转换为整数
              if(OVSys_State[0]==0x4C) and (OVSys_State[15]==0xDA):
                  print(OVSys_State)            #用于串口通信调试
      def Send_data(Send_data):
          global OVSys_State
          OVSys_State = Send_data
          uart.write(OVSys_State)
      ##TFT-LCD初始化
      #lcd.init()                #lcd函数初始化
      #lcd.set_direction(1)      #设置LCD显示方向 0和2是竖屏 1和3是横屏
      #摄像头初始化
      sensor.reset()                     #初始化相机传感器
      sensor.set_pixformat(sensor.RGB565)#设置相机模块的像素模式 16 bits/像素 GRAY为8
      sensor.set_framesize(sensor.QVGA) #设置相机模块的帧大小 320x240
      sensor.skip_frames(30)             #跳过30帧 让相机图像在改变相机设置后稳定下来
      sensor.set_auto_gain(False)        #关闭自动增益
      sensor.set_auto_whitebal(False)     #关闭默认的白平衡
      cross_roi = ([40,40,240,160])
      templates_cross = ["/cross0.jpg", "/cross1.jpg", "/cross3.jpg","/cross5.jpg"]
      #cross = ("/cross.bmp")
      #cross0 = image.Image("/cross0.jpg")
      #cross1 = image.Image("/cross1.jpg")
      #cross2 = image.Image("/cross3.jpg")
      #cross3 = image.Image("/cross5.jpg")
      ##cross_copy = cross.copy(cross_roi)
      #cross_copy.binary([0, 15])
      #cross_kpts = cross.find_keypoints(roi=cross_roi, max_keypoints=100, threshold=8, scale_factor=1.0)
      #主函数
      while (1):
          sensor.set_pixformat(sensor.GRAYSCALE)#设置摄像头为灰度图
          TRA_img = sensor.snapshot().histeq()#截一帧图像 加强对比度好分割
          TRA_img.mean(1)
          TRA_img.binary([(0,55)])
          #在LCD上打印帧率和OpenMV工作模式
          TRA_img.draw_string(0, 120,"OpenMv\rMode:\rTracking\rMode")
          TRA_img.draw_string(0, 200, "FPS:\r%.2f"%(clock.fps()))
      #    TRA_img.draw_rectangle(cross_roi)
      #    img_kpts = TRA_img.find_keypoints(roi=cross_roi, max_keypoints=100, threshold=8, normalized=True)
      #    if(img_kpts):
      ##        TRA_img.draw_keypoints(img_kpts,color=(255, 0, 0))
      #        match = image.match_descriptor(cross_kpts, img_kpts, threshold=100)
      #        if (match.count()>4):
      #            Send_data(Turn_Right)
      #            print("Turn Right")
          for t in templates_cross:
              cross = image.Image(t)
              r = TRA_img.find_template(cross, 0.60, step=3, search=image.SEARCH_EX)
      #    r1 = TRA_img.find_template(cross1, 0.60, step=3, search=image.SEARCH_EX)
      #    r2 = TRA_img.find_template(cross2, 0.60, step=3, search=image.SEARCH_EX)
      #    r3 = TRA_img.find_template(cross3, 0.60, step=3, search=image.SEARCH_EX)
              if r:
                  TRA_img.draw_rectangle(r, color=(255, 0, 0))
                  print("Turn Right")
          #偏移角度计算
          Centroid_Sum = 0    #初始化质心和
          for r in TRA_ROIS:  #是ROI的元组
              #找到视野中ROI区域的色块,merge=true,将找到的图像区域合并
              blobs = TRA_img.find_blobs(TRA_TH, roi=r[0:4], pixels_threshold=100, area_threshold=150,merge=True)
              if blobs:#如果找到了多个色块 计算质心和
                  maxb_index = Get_MaxIndex(blobs)#找到多个色块中的最大色块返回索引值
                  #返回最大色块外框元组(x,y,w,h) 绘制线宽为2的矩形框 不填充矩形
                  TRA_img.draw_rectangle(blobs[maxb_index].rect(), thickness = 2, fill = False)
                  #最大色块的中心位置标记十字
                  TRA_img.draw_cross(blobs[maxb_index].cx(),blobs[maxb_index].cy())
                  #计算质心和=(ROI中最大颜色块的中心点横坐标)cx*(ROI权值)w
                  Centroid_Sum += blobs[maxb_index].cx() * r[4]
          #中间公式 确定线心位置=质心和/权值和
          Center_Pos = (Centroid_Sum / Weight_Sum)
          Center_Error = Center_Pos - TRA_img.width()//2
          Deflection_Angle = 0#需要将线心Center_Pos转换为偏角 偏角初始化为0
          Deflection_Angle = -math.atan((Center_Pos-160)/60)#计算偏角 限制输出为正负53.13°
          Deflection_Angle = math.degrees(Deflection_Angle)#弧度值转换为角度
          #当偏角大于偏角阈值 且小于最大偏角 和STM32通信 小车左转
          Angle_err=Deflection_Angle
          if abs(Deflection_Angle) > 45:
              if Deflection_Angle>0:
                  Send_data(RRight)
                  print("RRight")
              if Deflection_Angle<0:
                  Send_data(LLeft)
                  print("LLeft")
          elif abs(Deflection_Angle) > TRA_AngTH:
                      Send_data(Right)#和STM32通信 小车左转
              #time.sleep(10)
                      TRA_img.draw_string(0,0,"Car:\rRight")#LCD显示小车运动状态
                      print("Right")#用于程序终端调试
                      print("Turn Angle: %f" % Deflection_Angle)
          #当偏角小于负的偏角阈值 且大于最小偏角
              if Deflection_Angle < 0:
                      Send_data(Left)#和STM32通信 小车右转
              #time.sleep(10)
                      TRA_img.draw_string(0,0,"Car:\rLeft")#LCD显示小车运动状态
                      print("Left")#用于程序终端调试
          #当小车角度绝对值小于阈值
          if abs(Deflection_Angle) <= TRA_AngTH:
                      Send_data(Run)#和STM32通信 小车直行
                      TRA_img.draw_string(0,0,"Car:\rRun")#LCD显示小车运动状态
                      print("Run")#用于程序终端调试
      #            lcd.display(TRA_img)#在LCD上显示img图像
      请在这里粘贴代码
          if(Center_Error>50):
              Send_data(Left)
          if(Center_Error<-50):
              Send_data(Right)
          if(-50<Center_Error<50):
              Send_data(Run)
    • 模板太大了。你的模板需要153KB。正常只能用10KB左右的模板。
    • 这个模版是说一个图片的大小还是所有图片的大小
    • @gdfv 单个模板的大小
    • @kidswong999 我单个模板烧的进去,同样分辨率的多个图片就会有问题
