代码没有问题,但是运行发生中断。
import sensor import time from machine import UART,LED sensor.reset() # Reset and initialize the sensor. sensor.set_pixformat(sensor.RGB565) # Set pixel format to RGB565 (or GRAYSCALE) sensor.set_framesize(sensor.QVGA) # Set frame size to QVGA (320x240) sensor.skip_frames(time=2000) # Wait for settings take effect. clock = time.clock() # Create a clock object to track the FPS. black=(32,100,-128,127,-128,127) uart=UART(1,9600) LED("LED_RED").on() while uart.any()==0: continue LED("LED_BLUE").on() LED("LED_GREEN").on() while True: img = sensor.snapshot() # Take a picture and return the image. blobs=img.find_blobs([black],invert=True,roi=[0,100,320,48]) if len(blobs)==1: img.draw_rectangle([0,100,320,48]) img.draw_rectangle(blobs[0][0:4], color=(0,255,0)) uart.write('#'+str(blobs[0].cx())+'$') print('#'+str(blobs[0].cx())+'$') elif len(blobs)==0: uart.write('S') print('S') LED("LED_GREEN").off() while True: continue
Traceback (most recent call last): File "<stdin>", line 17, in <module> Exception: IDE interrupt OpenMV v4.5.5; MicroPython v1.22-omv.r22; OPENMV4P-STM32H743 Type "help()" for more information.
这句不是错误,指的是电脑IDE连接OpenMV后,发送中断停止OpenMV的程序。
