  • 用openmvplus训练模型两种物体目标检测,为啥跑出来帧率这么低
    • 用edge impulse训练,就两种模型,训练出来就8帧,好低啊怎么让他高
      net = None
      labels = None
      min_confidence = 0.5
      except Exception as e:
          (255,   0,   0),
          (  0, 255,   0),
          (255, 255,   0),
          (  0,   0, 255),
          (255,   0, 255),
          (  0, 255, 255),
          (255, 255, 255),
          # of our objects
              for d in detection_list:
                  [x, y, w, h] = d.rect()
    • 8帧不错了,正常。
