  • 我想加入LCD模块,但添加后电机的部分就没有反应了,这是为什么,需要怎么调整?
    • 这是我原来的程序,IDE的版本是 IDE 4.0.14,只使用LCD的部分时程序可以正常运行
      THRESHOLD = (0, 34, -16, 4, -1, 15) # Grayscale threshold for dark things...
      from pyb import LED
      import car
      rho_pid = PID(p=0.5, i=0,d=0.015)
      theta_pid = PID(p=0.001, i=0,d=0.01)
      circle=0
      LED(1).on()
      LED(2).on()
      LED(3).on()
      from machine import SPI, Pin
      from display import SPIDisplay
      lcd=display.SPIDisplay()
      sensor.set_vflip(False)
      sensor.set_hmirror(False)
      clock = time.clock()               # to process a frame sometimes.
      last_increase_time = time.time()-10
          for blob in img.find_blobs([THRESHOLD], roi=[0,0,80,60], x_stride=2, y_stride=2, invert=True,  pixels_threshold=1000, merge=True):
              current_time = time.time()
              if (current_time - last_increase_time >= 10):
                  circle += 1
                  last_increase_time = current_time
                  if circle % 2 != 0:
                      start_time = time.time()
                          elapsed_time = current_time - start_time
                          car.run(30, 30)
                          if elapsed_time >= 0.1:
                              break
                          car.run(28 , 31 )
                          if elapsed_time >= 0.2:
                              break
                          car.run(30, 30)
                          if elapsed_time >= 0.4:
                              break
                         # time.sleep(0.1)
          line = img.get_regression([(100, 100)], robust=True)
          if (line):
              if line.theta()>90:
                  theta_err = line.theta()-180
              if line.magnitude()>8:
                  car.run(30+output, 30-output)
                  car.run(0,0)
              car.run(30,-30)
              pass
          #print(clock.fps())
          print(circle)
      以下是我添加LCD后的程序:
      import sensor, image, time,display
      from pyb import LED
      import car
      circle=0
      LED(1).on()
      LED(2).on()
      LED(3).on()
      #lcd = display.SPIDisplay()
          #lcd.write(img)
                  circle += 1
                  if circle % 2 != 0:
                          car.run(30, 30)
                              break
                          car.run(28 , 31 )
                              break
                          car.run(30, 30)
                              break
                         # time.sleep(0.1)
          if (line):
              if line.theta()>90:
                  car.run(0,0)
              car.run(30,-30)
              pass
          #print(clock.fps())
          print(circle)
      car.py程序如下:
      from pyb import Pin, Timer
      inverse_left=False
      inverse_right=False
      ain1 =  Pin('P0', Pin.OUT_PP)
      ain2 =  Pin('P1', Pin.OUT_PP)
      bin1 =  Pin('P2', Pin.OUT_PP)
      bin2 =  Pin('P3', Pin.OUT_PP)
      ain1.low()
      ain2.low()
      bin1.low()
      bin2.low()
      pwma = Pin('P7')
      pwmb = Pin('P8')
      tim = Timer(4, freq=1000)
      ch1.pulse_width_percent(0)
      ch2.pulse_width_percent(0)
      	if inverse_left==True:
      		left_speed=(-left_speed)
      	if inverse_right==True:
      		right_speed=(-right_speed)
      	if left_speed < 0:
      		ain1.low()
      		ain2.high()
      		ain1.high()
      		ain2.low()
      	ch1.pulse_width_percent(int(abs(left_speed)))
      	if right_speed < 0:
      		bin1.low()
      		bin2.high()
      		bin1.high()
      		bin2.low()
      	ch2.pulse_width_percent(int(abs(right_speed)))
      pid.py的程序如下:
      from pyb import millis
      from math import pi, isnan
      class PID:
      _RC = 1/(2 * pi * 20)
      def init(self, p=0, i=0, d=0, imax=0):
      self._kp = float(p)
      self._ki = float(i)
      self._kd = float(d)
      self._imax = abs(imax)
          tnow = millis()
          dt = tnow - self._last_t
          output = 0
              dt = 0
              self.reset_I()
          self._last_t = tnow
          output += error * self._kp
                  derivative = 0
                  self._last_derivative = 0
              self._last_error = error
          output *= scaler
              output += self._integrator
          return output
      def reset_I(self):
          self._integrator = 0
    • 可能是引脚冲突了
    • 就是引脚冲突了,LCD不能和电机扩展板同时使用。
