  • 新买的openmvh7plus,运行模板的hello word代码为什么这么暗,用之前不是plus的就很亮,代码一样的
    • # This work is licensed under the MIT license.
      # Hello World Example
      import sensor
      sensor.set_framesize(sensor.QVGA)  # Set frame size to QVGA (320x240)
      sensor.skip_frames(time=2000)  # Wait for settings take effect.
          clock.tick()  # Update the FPS clock.
          img = sensor.snapshot()  # Take a picture and return the image.
          print(clock.fps())  # Note: OpenMV Cam runs about half as fast when connected
    • 联系售后检查一下。
