小车中央时停止
各位大佬大家好,我有一个非常严肃的问题想问大家,我想让小车缓缓经过物料(物料为长方体,有固定颜色),在物料处于小车中央的摄像头中央时停止,请问我应该怎么设计程序呢?我几天一直在查,发现有以下几种方法:1.利用ROI,把ROI变得适当的小,然后当ROI区域内检测到相应颜色,即if blobs时候,小车停止。
2.我打算利用色块的坐标,即img.draw_string(100,100,'x='+str(blob.cx()), color=(0,0,0))
img.draw_string(100,100,'y=+'str(blob.cy()), color=(0,0,0)),当相应颜色的坐标处于屏幕中央的时候小车停止。
我刚刚入门,只能想出这两种办法,希望好心人能帮我分析下可行性,或者提出更好的建议,谢谢了!!!救救孩子
此回复已被删除!
@kidswong999 您好,我已经对我的程序进行了相应的修改,我把小车停止模拟成了小灯亮,但是无法实现啊,请问是不是我的程序有错误啊?而且运行起来的时候一卡一卡的,是不是我有什么地方写错了啊
# Single Color RGB565 Blob Tracking Example # # This example shows off single color RGB565 tracking using the OpenMV Cam. import sensor, image, time,pyb threshold_index = 0 # 0 for red, 1 for green, 2 for blue # Color Tracking Thresholds (L Min, L Max, A Min, A Max, B Min, B Max) # The below thresholds track in general red/green/blue things. You may wish to tune them... #将蓝灯赋值给变量led led = pyb.LED(3) # Red LED = 1, Green LED = 2, Blue LED = 3, IR LEDs = 4. usb = pyb.USB_VCP() # This is a serial port object that allows you to # communciate with your computer. While it is not open the code below runs. thresholds = [(30, 100, 15, 127, 15, 127), # generic_red_thresholds (30, 100, -64, -8, -32, 32), # generic_green_thresholds (0, 30, 0, 64, -128, 0)] # generic_blue_thresholds sensor.reset() sensor.set_pixformat(sensor.RGB565) sensor.set_framesize(sensor.QVGA) sensor.skip_frames(time = 2000) sensor.set_auto_gain(False) # must be turned off for color tracking sensor.set_auto_whitebal(False) # must be turned off for color tracking clock = time.clock() #ROI=(80,30,15,15)#左上方 # Only blobs that with more pixels than "pixel_threshold" and more area than "area_threshold" are # returned by "find_blobs" below. Change "pixels_threshold" and "area_threshold" if you change the # camera resolution. "merge=True" merges all overlapping blobs in the image. while(True): clock.tick() img = sensor.snapshot() for blob in img.find_blobs([thresholds[threshold_index]], pixels_threshold=200, area_threshold=200, merge=True): img.draw_rectangle(blob.rect()) img.draw_cross(blob.cx(), blob.cy()) led.on() time.sleep(600) #此处为lcd输出XY坐标img.draw_string(100,100,'x='+str(blob.cx()), color=(0,0,0)) #img.draw_string(100,100,'y=+'str(blob.cy()), color=(0,0,0)) # thresholds[0]为色域的第一个,即为红色,见视频颜色16min if blob.cx()==img.width()/2: led.on() time.sleep(600) print(blob) #rotation为旋转的弧度,通过这个来确认垂直时候停止 print(blob.code()) #打印出来相应颜色的代码,可以通过这个进行串口通信 #通过90度,小RIO,代码确定为红色,从而进行相应的定位
不好意思,已经弄懂了,只要把语句对齐就好了
@openmv萌新 哥我问一下如果相应的颜色位于中央小车停的程序怎么写啊
