  • 串口通信,openmvide串行终端发送的数据和星瞳助手接收的数据不一样?
      THRESHOLD = (18, 61, 14, 89, -2, 63) # Grayscale threshold for dark things...
      import sensor, image, time,ustruct
      from pyb import UART,LED
      #from pid import PID
      #rho_pid = PID(p=0.4, i=0)
      #theta_pid = PID(p=0.001, i=0)
      import pyb
      LED(1).on()
      LED(2).on()
      LED(3).on()
      #sensor.set_vflip(True)
      #sensor.set_hmirror(True)
      uart = UART(3,115200)   #定义串口3变量
      #识别区域
      roi1 =     [(0, 17, 15, 25),        #  左  x y w h
                  (65,17,15,25),# 右
                  (30,0,20,15),#上
                  (0,0,80,60)]#停车
      def outuart(x,a,flag):
          global uart;
          f_x=0
          f_a=0
          if flag==0:
              if x<0:
                  x=-x
                  f_x=1
              if a<0:
                  a=-a
                  f_a=1
          if flag==1: #十字
              x,a,f_x,f_a=(0,0,0,1)
          if flag==2: #上左
              x,a,f_x,f_a=(0,0,1,0)
          if flag==3: #上右
              x,a,f_x,f_a=(0,0,1,1)
          if flag==4: #stop
              x,a,f_x,f_a=(1,1,1,2)
          #data = bytearray(frame)
          data = ustruct.pack("<bbhhhhb",      #格式为俩个字符俩个短整型(2字节)
                         0x2C,                      #帧头1
                         0x12,                      #帧头2
                         int(x), # up sample by 4   #数据1
                         int(a), # up sample by 4    #数据2
                         int(f_x), # up sample by 4    #数据1
                         int(f_a), # up sample by 4    #数据2
                         0x5B)
          if flag!=1:
              uart.write(data);  #必须要传入一个字节数组
              for x in range(50):
                  time.sleep_ms(1)
      p9_flag=0 #p9需检测从低变高
      not_stop=0
          left_flag,right_flag,up_flag=(0,0,0)
          for rec in roi1:
                  img.draw_rectangle(rec, color=(255,0,0))#绘制出roi区域
          p = pyb.Pin("P9", pyb.Pin.IN)
          print(p.value())
          if p.value()==0:
              p9_flag=1
          if p.value()==1 and p9_flag==1:
              not_stop=1
              p9_flag=0
          if (line):
              if line.theta()>90:
                  theta_err = line.theta()-180
              #直角坐标调整
              #画出直线
              #print(rho_err,line.magnitude(),rho_err)
              if line.magnitude()>8:
                  #rho_pid直线左右偏移的距离,theta_err角度偏移
                  #rho_output = rho_pid.get_pid(rho_err,1)
                  #theta_output = theta_pid.get_pid(theta_err,1)
                  #output = rho_output+theta_output
                  outdata=[rho_err,theta_err,0]
                  print(outdata)
                  outuart(rho_err,theta_err,0)
                  if img.find_blobs([(96, 100, -13, 5, -11, 18)],roi=roi1[0]):  #left
                      #print('left')
                      left_flag=1
                  if img.find_blobs([(96, 100, -13, 5, -11, 18)],roi=roi1[1]):  #right
                      #print('right')
                      right_flag=1
                  if img.find_blobs([(96, 100, -13, 5, -11, 18)],roi=roi1[2]):  #up
                      #print('up')
                      up_flag=1
                  #if not img.find_blobs([(96, 100, -13, 5, -11, 18)],roi=roi1[3]):  #stop
                      ##print('up')
                      #stop_flag=1
                  if left_flag==1 and right_flag==1:
                      outuart(0,0,1)
                      #time.sleep_ms(5)
                      print('shizi')
                      continue
                  if left_flag==1 and up_flag==1:
                      outuart(0,0,2)
                      print('up-left')
                      continue
                  if right_flag==1 and up_flag==1:
                      outuart(0,0,3)
                      print('up-right')
                      continue
                  #if stop_flag==1:
                      #outuart(0,0,4)
                      #print('stop')
                      #continue
                  #car.run(50+output, 50-output)
                  #outuart(0,0,4)
                  ##car.run(0,0)
                  #print('stop')
                  pass
              #car.run(50,-50)
              outuart(0,0,4)
              #if  not_stop==1:
                  #time.sleep_ms(1000)
                  #not_stop=0
              print('stop')
          #print(clock.fps())
    • 星瞳串口助手,选择hex显示,不要选择utf8
    • 为啥不能用utf-8
    • 因为你发的不是utf8编码的字符串。
      如果你OpenMV端用uart.write("你好"),你就可以在串口助手里用utf8看到字符串。
